Old 05-23-2015, 07:01 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Factory thermostat is a "160 degree" unit confirmed
Just started tearing into the Z to swap heads/cam and confirmed the factory thermostat is 70 degrees Celsius or 158 degrees Fahrenheit. So much for all the posts about a 160 thermostat is a horrible thing...blah!
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-23-2015, 11:03 PM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
To confirm, who said the 160f thermostat was a horrible thing, other Z/28 owners?
Old 05-24-2015, 06:40 AM   #3
Stephen12ZL1
Drives: '21 ZLE A10
all of the "modders" in every forum. Z/28 guys have nothing to worry about...lol!
Old 05-24-2015, 06:42 AM   #4
Stephen12ZL1
Drives: '21 ZLE A10
read this: http://www.camaro5.com/forums/showth...160+thermostat
Old 05-24-2015, 08:46 AM   #5
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
It revolves around the idea that you can't tune the ECM to operate the fans below 192.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 05-26-2015, 04:12 AM   #6
ZL1-QTR
#00193
ZL1-QTR's Avatar
Drives: 14 ZL1 - 12 CT
Good to know! Thanks for sharing.
ZL1-QTR is offline   Reply With Quote
Old 05-26-2015, 09:05 AM   #7
EFI
EFI's Avatar
Drives: something faster than you
This.
Not only that, but you're comparing a track oriented and purposely built car to regular everyday street cars. On Z28s, the engineers can afford to lose a little bit of fuel mileage and motor life to make the car perform better and last longer under severe conditions.
Most people that only say that 160* tstats are bad don't know what they are talking about. They are perfectly fine although they do come with some cons...that's all. And like I mentioned before, a car like the Z28 is can be ok with those cons. A run of the mill Camaro or even other peformance car not so much.
EFI is offline   Reply With Quote
