06-04-2015, 08:44 PM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
B-3 cam idle video
Had a bench flash done today for a very basic calibration for the new heads/cam setup and wanted to post a quick idle video. I haven't been aggressive with the throttle because the weather has been horrible. Honestly, the cam matches the aggressiveness of the car, and I hope to see some nice hp numbers from the swap. My dyno tune is in two weeks to finalize everything.
06-05-2015, 06:44 AM | #2 |
Drives: 2013 silver ZL1 Join Date: Apr 2013
2015 Z28 Black #16 600rwhp N/A
Colorado speed and performance build: hand ported heads, titanium valves, hand ported throttle body,fast lsxr intake, custom cut lunati cam, lunati push rods, fm high performance lifters, dual beehive springs + titanium retainers, trunnions upgrade, ARH headers + x pipe, fast fuel rails, c5r timing chain, katech high volume oil pump, ati underdrive pulley, Taylor wires. Sold---2013 ZL1 M6 Silver Ice Metallic: 767 rwhp |
06-05-2015, 09:23 AM | #3 |
Drives: 2016 Nightfall Gray Metallic SS Join Date: Dec 2013
Sounds awesome!!!! Looking forward to seeing the numbers.
2016 Nightfall Gray Camaro SS |
06-05-2015, 11:52 AM | #4 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
That is one angry cam.
06-06-2015, 11:24 AM | #5 |
Drives: 2013 ZL1 Camaro 2000 SLP Camaro Join Date: Oct 2012
I like it.
2013 ZL1 748rwhp & 733 rwtq ( 93 tune )
06-06-2015, 11:34 AM | #6 |
Drives: 2015 camaro Z/28 Join Date: Apr 2015
Did you use stock heads? Where the valves stems loose in the heads?
Black 2015 camaro z/28 #445 with ac
06-06-2015, 11:36 AM | #7 |
Jumanji
06-06-2015, 12:04 PM | #8 |
But when he took the stock heads off did he see the problem that corvette had with the ls7?
06-06-2015, 04:38 PM | #9 |
valve stems are o.k. on my stock heads as far as I can tell. Guides are a problems in the stockers sometimes. I did swap the heads and cam.
06-10-2015, 12:20 PM | #10 |
Drives: 96SS Join Date: May 2009
Sounds good
06-10-2015, 04:32 PM | #11 |
