07-06-2015, 06:15 PM | #1 |
Drives: Midnight Blue Camaro SS Join Date: May 2015
Stability service
So I was changing out the headers on my camaro and disconnected the battery and had my car on stands and once I turned it on the stability service control sign pops up it does go away but then it comes right back is there anyone with any idea why this might have happened
07-06-2015, 06:17 PM | #2 |
Drives: 2014 2LT RS Join Date: Apr 2015
I was looking for a blown fuse and it came on but went away after a few hundred yards down the road. I am thinking it comes on for any issue instead of something that says what the real issue is.
07-06-2015, 06:21 PM | #3 |
Thanks will keep looking for any little sign . But still do you think it's safe to drive and to use as a daily ?
07-06-2015, 06:23 PM | #4 |
if it will not go away, find out why. no I would not keep driving it with an unknown fault. get the codes read
07-06-2015, 06:30 PM | #5 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Maybe drive with a little more awareness of how hard you're driving and how much grip is available to your car's tires.
Just because your ST is inop does not mean that your car is going to suddenly spit you off the road for no reason at all; that'd be up to you for doing something careless or stupid. But you should get it checked out and any faults corrected. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
07-06-2015, 06:45 PM | #6 | |
07-06-2015, 07:14 PM | #7 |
Good call.
I wouldn't want to second-guess what anybody's stability control system may be correcting its basic vehicle for. Not since I know that the "fix" for lift-throttle oversteer in one particular SUV was to recalibrate the vehicle's ESC rather than fix the problem mechanically/physically. Norm
07-06-2015, 08:11 PM | #8 |
Misfire? Cracked spark plug? Wires not on tight enough?
07-06-2015, 08:19 PM | #9 |
Drives: 2015 2SS/RS 1LE Join Date: Jul 2014
Assuming the CEL is on, get the codes read. This happened to me once, and I freaked out just like you probably are. I checked the codes and all four passenger injectors were open due to a blown fuse under the hood. 20 amp fuse later and back to normal. Keep us posted!
07-06-2015, 11:33 PM | #10 |
07-06-2015, 11:35 PM | #11 | |
07-07-2015, 06:03 AM | #12 |
Glad to hear that it was a minor issue. It is always scary with these 'newer' cars because they are so dependent on the incredible amount of electronics. Something so simple can make the car act like there is something seriously wrong.
Tags |
5th gen, camaro, cel abs traction control brake, stability control service |
