07-26-2015, 03:26 AM | #1 |
Drives: 2014 ZL1 Convertible Join Date: Apr 2014
Just want tires that will stick
I've been reading a lot but I still struggle with a simple idea about traction.
I hate my stock ZL1 tires, they aren't sticky at all. I have a set of 285 sottozero's I use in the winter time (no rain or snow) and the acceleration with these is incredible. I want a tire that gives me the same in the summer. I've search and I see the Toyo R888's are supposed to be good for acceleration but when I see a tire that is basically bald, I just think it will spin. There is nothing to grip the ground with. My Sottozeros have all kinds of grooves that grip the ground. I do not care about speed, ride comfort, noise, wear, or rain etc. I just want a tire that will perform off the start. Any suggestions?
[ The Physicist ]: d^2x(t)/dt^2 addict!
07-26-2015, 04:14 AM | #2 |
Drives: 2015 Red Hot SS/RS M6 Join Date: Sep 2012
I'm really impress with the amount of grip I'm getting from the stock P-Zeros on my SS.
07-26-2015, 05:22 AM | #3 | |
07-26-2015, 12:57 PM | #4 |
Thank you ...
I guess I should mention I want the tires to stay on the stock ZL1 rims too. Mikes-ZL1 : have you tried other tires to compare them against? They do sound awesome, so I'm happy to hear a zl1 owner say this.
07-27-2015, 07:41 AM | #5 |
Drives: 2012 Camaro ZL-1 SIM Join Date: Sep 2008
I switched over to the Michelin Pilot Super Sport:
245/40/20 275/35/20 IMHO, they maintained their grip much longer than the Goodyears and the tirewear is much better. With the Goodyears, I was replacing them every 12,000 miles because I lost so much grip.
07-27-2015, 08:13 AM | #6 |
Drives: 2011ShelbyGT500 Join Date: Jan 2014
I run Nitto 555R's on my Shelby for street tires.
685 RWHP 711 Torque |
07-27-2015, 04:15 PM | #7 |
Grooves don't grip, rubber on the ground does. Grooves are for bad weather and rain, not traction. There is a reason a slick is a slick. R888s are amazing tires. Best tire made if you don't want to give up handling. Otherwise check out the ET streets or NT05Rs.
Nick
Corvette Z06 -1200ish rwhp |
07-27-2015, 09:31 PM | #8 | |
JRE 750 HP package
Rag Top Rob |
07-28-2015, 10:50 AM | #9 | |
Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
Not sure what the middle number indicates and if it makes a difference being 5 less than the MT ET's an NT05R's. Edited to add that I searched and the middle number represents the sidewall height. 35 = 35% The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. The 35 indicates that the sidewall distance, from the wheel rim to the outside of the tread, is 35% of the section width. Last edited by cal45; 07-28-2015 at 08:18 PM. |
07-29-2015, 11:10 PM | #10 | |
I cant compare to a slick as they are deflated and soft for racing only. Generally speaking, I want a street tire that is sticky as hell and my winters are the only ones that fair up to the task.
07-30-2015, 07:37 AM | #11 |
Drives: 2012 SIM ZL1 Join Date: Dec 2010
Are you running those up front as well?
2012 Chevrolet Camaro ZL1 691/649 DC Porting S/C Port NW 103mm, ported snout MPI LSA Lid w/ reinforced brick DSX Flex Fuel conversion FIC 1200's LSA 2.5” upper METCO LSA pulley kit Comp camshaft: (236/242 .602/.610 113+3) HD supercharger belt DC Conservative Tune DSS Carbon Fiber Driveshaft BMR everything McLoed HD Clutch Roto-Fab CAI MGW Shifter Kooks 1 7/8” LT's Corsa Sport AFCO HX 315/30/20 R888R 285/35/20 R888R XPEL Ultimate PPF 35% Llumar tint Oracle LED sidelights ZL1 AddOns Wicker Bill |
07-30-2015, 09:09 AM | #12 | |
Drives: 2012 ZL1 Join Date: Sep 2014
Tread compound plays into this also. The surface area isn't the only factor for traction. Softer tires = better traction. |
07-30-2015, 09:12 AM | #13 |
CamaroFans.com
Straight Line or Curves?
07-30-2015, 09:47 AM | #14 |
Drives: 2013 AGM ZL1 BELLA* Join Date: Jan 2011
I'm running the Michelins PSS, 315s/295s and traction on them are night and day compared to the GYs as far a street driving. Now track, I will have a different set up.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella* 2010 MGM Toyota Tacoma 2010 CGM SS (Traded) 1996 Black SS (Sold) |
