Old 07-31-2015, 06:08 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Meth with LSA
So who all is running meth with a LSA or other roots style blowers? I'm currently spraying before the throttle body. I'm about to peak out my set up before going turbo this winter.
What I want to know before turning it up is how well is the meth disturbed to each cylinder when spraying before the throttle body?
In my head it seems like the front cylinders don't get as much as the rear.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 08-01-2015, 08:47 PM   #2
ToddB
Drives: 2011 2SS Convertible Supercharged
Mine sprays before the rotors so I would thing it gets mixed up very well. Haven't had and problems with it.
ToddB is offline   Reply With Quote
Old 08-01-2015, 09:25 PM   #3
2010_camaro
What's power do you make? You tuned for meth or just spraying?
Old 08-01-2015, 09:56 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
FYI, on LSA SC, ADM says no on meth...
-Don
747 RWHP 794 RWTQ
Old 08-01-2015, 11:21 PM   #5
2010_camaro
-Don
My car seems to think otherwise. The heat has dropped a ton and car pulls smoother on top end..
Old 08-01-2015, 11:39 PM   #6
hammdo
hammdo's Avatar
I believe it is more on how it treats the roots type blower and the protective coating...
But, Sack Rat (who is up at ADM) noted what I quoted...
http://www.camaro5.com/forums/showpo...2&postcount=43
It's ADM's approach...
Glad it's working for you! Smokum does not use it in his for the same reason...
Thanks!
-Don
747 RWHP 794 RWTQ
Old 08-04-2015, 09:05 PM   #7
Justin@CPR
Justin@CPR's Avatar
Drives: 2002 Trans Am
The coating on the rotor's thing is bunk. Yes it will slightly take some off, over an extremely long period of time. Look at any pd blower that has a lot of miles on it w/ no meth being sprayed, the teflon comes off on it's own eventually anyways. If you want to do meth go for it! We only run & sell alky control kits as they don't use any of the push lock stuff that will leak over time, plus the kits are vehicle specific and install flawlessly. If you want to do a kit let us know and we can set you up and answer any tech questions you may have when you install it.
Justin@CPR is offline   Reply With Quote
Old 08-05-2015, 08:31 AM   #8
2010_camaro
I have a snow performance progressive kit already. I'm just worried about each cylinder getting enough when being tuned. Idk how even it spreads threw the blower after going threw the rotors.
Old 08-05-2015, 08:33 AM   #9
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
We run methanol on a good number of ZL1, CTS-V, ZR1, and of course other vehicles equipped with the TVS blowers (weather stock, or aftermarket) and have never had an issue. One thing that we do if you are extra worried about it would be to keep the PCV system hooked up and allow the oil vapor to still enter the system. This will help add another layer of protection for the seals, and the rotors themselves so they are never dry.
Also, we only use M1 Methanol to ensure the proper purity, so I can't comment on anything other than this.
Livernois Motorsports is offline   Reply With Quote
Old 08-05-2015, 10:23 AM   #10
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Lots Of people Running it on the roots. Most will tell you not to run a mixture when spraying post TB into a Roots style though.. Only %100 as the water in the mixtured Water/meth fluid can get into the bearings and pull the oil out and it eats away at the rotors quicker.
Nighthawk89 is offline   Reply With Quote
Old 08-05-2015, 01:51 PM   #11
ToddB
I am tuned for it. Around 700 RWH
Old 08-06-2015, 08:10 AM   #12
2010_camaro
You spraying before the throttle body? 100% or a mixture?
Old 08-06-2015, 09:24 AM   #13
Justin@CPR
Justin@CPR's Avatar
We use 100% meth as most people's iat's will never get high enough to flash water and therefore you run the risk of it pooling.
Sent from my SM-G920V using Tapatalk
Old 08-06-2015, 10:06 AM   #14
2010_camaro
Is it save to run 100% with out being tuned for it?
