08-22-2015, 11:23 PM | #1 |
Drives: 2015 Camaro SS Join Date: Mar 2015
Drop springs recommendation?
Been going back and forth about which to go with, mostly brands. I know I only wanna drop the car about an inch just to get rid of the wheel gap. What do yall recommend as far as brands go and if 1 inch is a good idea or not (not trying to slam it I scrape enough as it is) and maybe for sway bars too? Those are definitely on my list
Thank You!!!! |
08-23-2015, 12:09 AM | #2 |
Drives: 2013 Corvette Base Coupe 3LT Join Date: Aug 2014
for 1" i would go BMR or Hotchkis. I was bouncing between the 2 when I was searching for my SS. I ended up buying the Hotchkis only due to a smoking deal i got for their Stage 1 kit (springs & sways). Hoping to get them installed in the next couple months. Having spoken with both BMR and Hotchkis' guys on the forums i don think you could honestly go wrong either way.
2013 Velocity Yellow Corvette Base Coupe 3LT
2011 Rally Yellow Camaro 2SS/RS Coupe - SOLD |
08-23-2015, 09:05 AM | #3 | |
08-23-2015, 03:02 PM | #4 | |
08-23-2015, 03:44 PM | #5 |
08-23-2015, 06:05 PM | #6 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Are the Hotchkiss springs linear and do you know the rates?
Thank you
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
08-24-2015, 09:35 AM | #7 |
08-26-2015, 10:33 AM | #8 |
MrRaspberryJam - BMR offers both 1" and 1.25" springs at a great value. Either choice will work well with the factory suspension.
Kind regards, -Adrian 888.308.6007 |
08-26-2015, 11:58 AM | #9 |
Drives: Camaro Join Date: Nov 2014
PFADT series aFe control drop springs and sway bars!
http://afepower.com/shop/application...ro&brandID=142 |
08-26-2015, 12:12 PM | #10 |
Drives: 2013 Camaro 2SS/RS M6 Join Date: Feb 2013
I just lowered mine with BMR's split drop springs, 1.4" in the front and 1" in the back. I would second BMR.
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs Build#24869 |
08-26-2015, 12:20 PM | #11 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
BMR I was told are linear is not progressive
08-26-2015, 12:50 PM | #12 |
Drives: Race Car Join Date: Sep 2009
08-26-2015, 04:41 PM | #13 |
09-13-2015, 10:34 AM | #14 |
Drives: 2015 Black SS RS Join Date: Sep 2015
also want to lower my 2015 SS 1in, will I need to change shocks/struts to match the new spring rate, and any other recommendations on other suspension mods to go with the lower stance. driving this car to work 100 miles per day curvy mountain roads, no track or race. any advice on best springs that keep closest to factory ride, thanks
