Old 10-18-2015, 01:50 PM   #1
jdarc1
jdarc1's Avatar
Drives: 2011 Camaro SS
2011 SS keeps stalling
I have a 2011 SS with a cam, kook headers, vararam CAI, heads and lax intake manifold. Car has been tuned also, dyno came I at 508 RWHP. Car is great but sometimes the car will stall when depressing the clutch when coming to a light or downshifting. Have been back to the tuner twice and car still does it. Keep in mind the last mods I did were the heads and manifold and the car was fine before those last upgrades. It really does it more when the A/C is on . Has anyone else had this problem? Could it be the new manifold? The tune shop can't figure it out . I also have a valve cover oil leak that he can't seem to fix either. Love the car but have been chasing these problems for 7 months now?
jdarc1 is offline   Reply With Quote
Old 10-18-2015, 01:53 PM   #2
CurtiSSWatson
CurtiSSWatson's Avatar
Drives: Black SS
Sounds like that last job they did resulted in them not putting it back together properly. Something is loose.
CurtiSSWatson is offline   Reply With Quote
Old 10-18-2015, 03:02 PM   #3
jdarc1
jdarc1's Avatar
They have had it in twice since them. Did a retune etc. wondering if anyone heard of this before with the mods I have.
Old 10-18-2015, 03:44 PM   #4
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I would look at the fuel trims and check for a vacuum leak.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 10-18-2015, 04:20 PM   #5
jdarc1
jdarc1's Avatar
Just spoke with my shop and he said they went through the fuel system and new rails and checked several times for a vacuum leak but found nothing.
Could it be the LSX manifold. Ive heard about them cracking or something like that internally.
Old 10-18-2015, 06:54 PM   #6
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Put your stock manifold back on and see if it goes away
Caswell239 is offline   Reply With Quote
Old 10-18-2015, 07:01 PM   #7
jdarc1
jdarc1's Avatar
@Caswell, that's what we are planning to try next.
Old 10-18-2015, 07:03 PM   #8
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
The old mechanic way of checking for vacuum leak is spray a little starting fluid or ether and see if the Rpms change.
Old 10-19-2015, 06:54 AM   #9
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
If that's not it, it must be the throttle in the tune. My car tuned had to have the throttle upped because it would fall flat when deceleration was out of gear,( coasting). and stall and die. Then would restart no problem but hey I have electric power steering so that helped not kill me.... Not the idle as that should be about 950..... the throttle...... I use Wongs performance engineering in Vancouver he does HP tuning and has the GM software too.
Old 10-19-2015, 07:50 AM   #10
Caseyls3
Drives: 2011 Camaro SS/RS Convertible
What is the idle set at?
2011 Camaro SS/RS Vert - Jewel Red Tintcoat, 6M, 231/247 Comp Cam, Kooks headers, Borla ATAK, ATI under drive pulley, Richmond 4.10s, LS9 clutch, Hurst shifter, BMR Springs
Caseyls3 is offline   Reply With Quote
Old 10-19-2015, 02:45 PM   #11
jdarc1
jdarc1's Avatar
I have a cam so the idle is around 900 or so.
Old 10-19-2015, 03:19 PM   #12
jdarc1
jdarc1's Avatar
@christian
My car will drop out when I depress the clutch but it only happens once in a while but more frequently when the A/C is on. Did you have the same problem?
Old 10-19-2015, 03:33 PM   #13
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
You should data log it and then it will show up. That way your tuner can see if it is in the tune or at least give him a direction to look.
KLR ZL1 is offline   Reply With Quote
Old 10-19-2015, 04:21 PM   #14
xc_SS/RS
Drives: 2010 Camaro SS/RS
Definitely go this route. Best way to do it before throwing parts at it.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
