11-11-2015, 09:47 PM | #1 |
Drives: 2010 Black 2ss Chevy Camaro Join Date: Nov 2011
Did I buy the right brake pads?
So I purchased these pads
http://www.amazon.com/gp/product/B00...ilpage_o00_s00 but I don't believe they are the same as the stock pads. I thought this part number is the same for the 2010 ss OEM brake pads. Should I return and purchase another or use these? Also they are really dirty and I am not even sure if they are brand new. All help is greatly appreciated, Shayne |
11-11-2015, 09:56 PM | #2 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
Look new to me
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA |
11-11-2015, 10:07 PM | #3 |
BUMBL Z
They look fine to me???
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
11-11-2015, 10:11 PM | #4 |
Oh lol, its just weird how some have those cirlces on top and some don't, will they run against my rims?
11-11-2015, 11:29 PM | #5 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
If you have the stock 20s or any 20in then no they wont. Just a possibility when you go with a smaller rim.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
11-12-2015, 09:50 AM | #6 |
Drives: charcoal Join Date: Oct 2013
11-12-2015, 11:33 AM | #7 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I switched to Hawk Ceramic brake pads. Almost no brake dust at all.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
11-12-2015, 01:30 PM | #8 |
Look like the stock replacements. The OE are the only ones with those rollers that I'm aware of. They will fit within the wheel.
Feel free to call, PM or email me anytime with questions. All the best, Jared Royce JDP Motorsports 888.308.6007 |
11-12-2015, 04:04 PM | #9 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
Those wheels (aka rollerskates) are weights GM added to help with noisy brakes. I can only guess GM made them wheels in case there was some sort of interference problem with the wheel????
Replacing my oem pads with Akebono.... can't stand the dust anymore. Only the OEM pads have those wheels on them. |
11-12-2015, 04:16 PM | #10 |
Drives: 2014 2SS/RS/1LE Join Date: Nov 2015
Do the aftermarket (non-oem/brembo) pads not have the rollerskates on them?
Mine are just now starting to get a little noisy so I'm going to pull them off and grease the pad backing and see if that helps. If not I may just get new pads but the pads I have still look good.
11-12-2015, 04:27 PM | #11 | |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
No Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
