Old 11-16-2015, 06:20 PM   #1
Carmikaze
HTCC Membership Director
Carmikaze's Avatar
Drives: 2013 RS Camaro
Info on 4 channel Rf remote switch
Anyone have any info on setup/wiring on one of these remotes from eBay/china? I am getting the power light, and the remote light comes on and I hear the relays click when I push A,B,C,or D on the remote, but I am not getting 12v on any of the outputs when I check with a meter when the remote button is held down. Board is set for momentary so power should be present when button is held depressed. Each output has NO/ground/NC. I have tried meter on ground and each of Normally Open and Normally Closed with no voltage present. Thanks
Carmikaze is offline   Reply With Quote
Old 11-16-2015, 06:22 PM   #2
Carmikaze
Carmikaze's Avatar
Here is a pic of the board
Old 11-16-2015, 07:13 PM   #3
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
You have it wired wrong. That is not "ground" that is common. You need to jumper 12 volts to each of your "common" terminals. Then connect your "load" to the NO terminal.
When you press the button the 12 volts will "pass thru" to your NO terminal.
You should have common to common to common to common to plus 12 volts.
The Black wires (neg) should not be on that board except in the power location. All the black (neg) wires from your loads should be tied to "Ground" elsewhere.
Rainbow1616 is offline   Reply With Quote
Old 11-16-2015, 07:40 PM   #4
Carmikaze
Carmikaze's Avatar
Ahhhhh, makes sense now. Thanks for the help.
