Old 12-01-2015, 07:13 AM   #1
camaro5grey
camaro5grey's Avatar
Drives: 2014 2SS/RS 6M
HELP!!! NEED TO PASS STATE INSPECTION!!!
I live in Texas and state on the horizon. I installed SLP LT headers, cats, LM exhaust on my LS3. I had a guy tune out the CEL codes it was popping up and the CEL keeps coming back. I think the fault is a p015d delayed bank pre-O2 sensor?
What do I need to do to properly tune out the CEL so the readiness codes set?
camaro5grey is offline   Reply With Quote
Old 12-01-2015, 07:56 AM   #2
Mike_G
Drives: 2010 2SS/RS
Have you talked to your tuner about the problem? If so and they can't fix it, find a new tuner.
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 12-01-2015, 07:58 AM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
You most likely have delayed response from the front sensors being farther back ....... The deal is you tune that out in a good tune by basically saying hey ignore it in the tune.... and disabling that code.....
Old 12-01-2015, 08:57 AM   #4
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
Your tuner sucks
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
Old 12-01-2015, 09:45 AM   #5
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
That is a code that started showing up on the 2014-2015 Camaro's. I'd call your tuner and it will be fixed in 5 minutes.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 12-01-2015, 10:22 AM   #6
camaro5grey
I also don't think he fixed the readiness codes to show the are good...otherwise Id get the car inspected and then fix the CEL later.
Old 12-01-2015, 10:26 AM   #7
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Get a new tuner if he isn't doing what he claims he did. Plenty of reputable shops. But definitely give him a chance to fix, if it wont cost anything to you.
Old 12-01-2015, 10:37 AM   #8
camaro5grey
I appreciate the help guys!!! Ill be calling him today to ask him about the issue.
Old 12-01-2015, 01:16 PM   #9
Jester06
Drives: 2013 White L99 SS
Kind regards,
Jordan Priestley
888.308.6007
Also appears on the 2013's as well. That same code came up the day after I had my car tuned
Current HP/Torque: 413HP/413 Torque
Current mods: Pfadt Tri-y Headers with Hi-Flow Cats, VMAX CNC Ported Throttle body, CAI intake by Cold Air Inductions, Apex Air Scoop/Washer relocation set, RX Catch Can, Stainless Works 3" retro Chambered cat back exhaust, Flex Fuel sensor, 3.91 gear ratio, BMR rear trailing arms, BMR Rear Toe rods
Future Mods: GPI's SS3 VVT cam, 3600 stall triple disc torque converter, Fast LSX 102mm throttle body
Jester06 is offline   Reply With Quote
