12-19-2015, 12:24 PM | #1 |
Drives: 2014 ZL1 Join Date: Dec 2015
ZL1 factory clutch issues
I recently purchased a 2014 ZL1 with 15,000 miles. Probably around 600rwhp at the moment. I noticed during a couple pulls last weekend that in 4th gear at high rpm's there was repeated slight hesitation, and what smelled like burning clutch. Do the factory clutches really go bad at the 600whp range? I realize the previous owner could be the issue......
12-19-2015, 12:44 PM | #2 |
You would think a twin disk could handle more HP than that......any help would be appreciated guys. Thank you
12-19-2015, 12:50 PM | #3 |
2.55 upper pulley, cai, stainless works 3 inch headers, 1000cc injectors, ron davis heat exchanger, NGK tr7ix plugs gapped at .32. Those are my mods......haven't had the car on the dyno yet, but I'm assuming I'm somewhere around the 600whp mark.
12-19-2015, 12:57 PM | #4 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
I am at 700 RWHP and never had an issue with the clutch.
Bryan 2018 ZL1 M6
12-19-2015, 01:02 PM | #5 |
Hmmmm.........well now I'm a bit nervous. ha
12-19-2015, 02:15 PM | #6 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
They are great, but I slipped mine once at the track and it's been downhill every since. I did change out the fluid and a bunch of downshifts brought it back, but it has never been the same. Anytime it gets hot it slips. Will change it over winter and I expect to see the flywheel scuffed with material. Previous owner maybe did the same on yours?
12-19-2015, 06:27 PM | #7 |
How much power are you making?
12-19-2015, 06:34 PM | #8 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
Zero problems with mine until I started No Lift Shifting then it slips just a bit on my 3-4 shift while racing. But mine goes away if I am hard on the clutch so I try not to baby it.. Try Driving it like you stole it!!
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
12-19-2015, 07:52 PM | #9 |
12-20-2015, 01:06 PM | #10 |
709 RWHP & 677 RWTQ
Drives: 13' HPE 800 ZL1..... IOM vert, M6 Join Date: Feb 2013
Smoked mine quickly launching on street tires, slipping it to get out of the hole.
11.34 @ 124.88
12-21-2015, 06:23 AM | #11 |
I think the GTO clutch reservoir helps preserve clutch life by letting you keep the fluid clean. I had at least several hundred runs on a stock LS3 clutch on a TT 1LE on drag radials. A twin disk is better (Stay away from Centerforce) at holding big power but very difficult to launch.
"Democracy Dies in Darkness" |
03-30-2016, 11:55 PM | #12 |
Drives: Black M6 2013 Join Date: Dec 2012
Just burned up My clutch. I put Mickey Thompson ss on and they stick like glue, Then tried launch control mode 5 and the revs hit 6k and there was an awful smell. Not tire smoke. My car has 21K and alot of nolift shifting and using launch control plus 10% pulley and tune. Got home and ordered a new one. Plan on replacing it Myself . Bummer.
03-31-2016, 08:08 AM | #13 |
Gearhead
Drives: 2012 ZL1 Join Date: Jun 2014
Driving habits/behavior are a huge factor in clutch life. It doesn't take long for someone to smoke the clutch if they are slipping it (intentionally or otherwise).
If there is a problem, get in there and fix it.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip. 11.193@128.13 in 515' DA |
03-31-2016, 11:09 PM | #14 |
Drives: 2012 Nickey ZL1 #001, 2014 Corvette Join Date: Feb 2011
Hopefully my link to this thread works and helps. Bottom line, hard to say what the previous owner may have done, but I do believe there are issues with the clutch system at high RPM shifts and launches. Experts across the nation have pointed their fingers at just about everything to include: the actual OEM and some after market clutches, installing a heavier pedal return spring, master cylinder, GM using brake line AN fittings and lines instead of the larger AN fittings and lines normally used for clutch lines, and the brake and clutch systems sharing the same reservoir. I personally think its all of the above plus then we go add more hp to a heavy car with big fat sticky tires, something has to give, right? I guess its good that it is the clutch that is giving out. Read the below thread and then do a search and you will find many discussions and many recommendations as to what clutch to replace it with and/or any mods to the system to improve performance so you aren't replacing it again. I've gone through a few clutches until I got the triple disk, along with lots of other changes in the clutch system.
http://www.camaro5.com/forums/showth...42#post8571642 Last edited by Nickey31; 03-31-2016 at 11:20 PM. |
