12-27-2015, 09:33 PM | #1 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
Wheel Hop
Can any SS owners comment on the wheel hop of the 6th gen? The 5th gen was brutal so I'm hoping they fixed it.
12-27-2015, 10:36 PM | #2 |
Drives: 2016 Garnet Red 2SS Join Date: Feb 2012
One of the suspension engineers I talked to at the reveal said he had done over 500 launches without ever getting wheel hop on the sixth gen. I do hope he wasn't blowing smoke.
12-28-2015, 01:06 AM | #3 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Check out this video of David Leone discussing the complete elimination of the wheel hop in the ATS-V. It comes in at the 9:05 mark:
I suspect that the Camaro employs this technique as well. And I suspect that it is working, considering the 0-60 times for both cars. |
12-28-2015, 06:58 AM | #4 |
I hope the smaller half shaft isn't weak
12-28-2015, 07:47 AM | #5 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
12-28-2015, 08:17 AM | #6 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Different stiffness half shafts is not new. GM used that in the original CTS-V years ago to calm that down after the initial launch as I recall. That car had power hop worse than anything I can remember. I believe it's also how control torque steer on FWD cars.
12-28-2015, 08:40 AM | #7 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
I can say the tires break lose before wheel hops occurs. It is a smooth transition too. No wheel hop for me and
i tend to break the tires lose daily with traction control on. I am still in break in period too. This car is a beast! |
12-28-2015, 10:07 AM | #8 | ||
Drives: 2013 370Z sports Join Date: Sep 2015
12-28-2015, 10:29 AM | #9 | ||
http://www.mototuneusa.com/break_in_secrets.htm And, here is a link to the MotoMan who reviews cars: The Cadillac Engineer was referencing the latter. |
12-28-2015, 10:33 AM | #10 |
Drives: 2016 F150 Join Date: May 2014
The wheel hop on my Mustang is ridiculous. The whole car wants to fall apart.
12-28-2015, 10:37 AM | #11 | |
Daily Driver 24/7 365
Drives: '15 CRT 2SS/RS/1LE Join Date: Jul 2015
Once I put on A/S or Winters the wheel hop will go away and they'll just be leaving rubber on the road, lol.
NPP Fuse Pull, Z28 CAI =
Previous Rides: 2005 Magnum R/T A5 CAI, Cat-Back 2014 RRM Camaro 1LT/RS A6/NPP CAI Follow Me On Instagram! |
12-28-2015, 10:48 AM | #12 |
There's no way it's too weak, they just increase the size of the other one, and make sure the ratio of the two are non integer multiples of each other. If you divide 30/55 you get 0.54545454......
You can't get a harmonic oscillator going with that ratio. End of wheel hop. They use the same math to make sure bridges don't fall apart in the wind like this: https://search.yahoo.com/yhs/search?...&hsimp=yhs-004 It's the same math they use to figure out where to brace large radio antenna as well. If you brace at the top, and 1/2 or 1/4 away from the top (or any integer fraction/multiple), the antenna will vibrate in a stiff wind like a guitar string and fall apart. If you place the second brace something like 0.54545454.... from the top brace, no standing waves can occur. If the engineers are smart enough to figure out wheel hop is caused by the twisting of the drive shafts acting like a spring to store energy, then vibrating back and forth as an harmonic oscillator, we can be safe in assuming they weren't stupid enough to not figure out to make sure the smaller one can handle the full load. Plus, GM has used this technology on other cars, I'm sure they would have figured that out by now, even if they did. Also, if you look at the Camaro's power to weight ratio and trap speeds, and compare that to the 0-60 times, you can see this car is hooking up on launch very well. Whatever they did, it works, and that's all I care about. |
12-28-2015, 10:51 AM | #13 |
12-28-2015, 10:53 AM | #14 |
マスタング = 遅い
S197 right? The manual one I had would get some hop if I wasn't smooth with the launch, but a set of BMR LCA's fixed that...funny thing is my current auto one doesn't hop what so ever...
