#1 | |
![]() ![]() Drives: 93GMC sierra stepside/ ctsv3 Join Date: Dec 2011
Fully Built 2012 Camaro IOM Price drop
Ive decided to sell my Camaro, I have put a lot of time into this car and when you see it.. it shows.
The car has almost 13k miles on it right now and only almost 3k miles on the new fully built motor, below is the list of modifications I have done yo the car TMS ( Thompson Motor Sports ) LSX 418 c.i. 10.1 compression Rated For 1500hp 4.000'' crankshaft Thompson motorsports 6.125" connection rods Diamond Pistons Performance file fit ring set King racing narrowed rod &main bearings GMPP cam Bearings Arp main studs Arp head bolts Melling high pressure oil pump Prc 260 6 bolt heads with ls9 head gaskets Brian Tooley rocker Arm Turnion Upgrade Brian Tooley Pushrods C5 R timing chain ls2 chain dampener Custom Ground Turbo Cam 235*-244*-118 +4* .638” .622” Stock ls3 intake with Nasty Nate Fuel rails 129lbs Fuel injectors Lokar Oil dip stick Mcload RXT clutch with remote bleeder Ideal Garage modified clutch slave cylinder MGW Full replacement shifter with 2013+ shift knob Improved Racing Dynamics 180degree oil cooler block with added Mishimoto 19 row aluminum oil cooler Fore Innovation Level 4 dual fuel system ( 2 Walbro 450's ) with -8an feed and -10 return fuel lines and reusable fuel filter DeWitt's high performance aluminum direct fit radiator RX color matched catch can Pro Sport A/F and Boost gauge with pillar pod Poly motor mounts Texas speed 2 inch into 3inch long tube headers Kooks full 3 inch exhaust header back no cats Pedders supercar coil overs Pedders steering rack bushings Pedders radius rod bushings Pfadt trailing arms Pfadt Solid rear sub frame bushings JP Superior Solutions rear sway bar ZL1 Front 6 piston Brembo brakes ( front and rear calipers have been professionally powder coated ) Gforce engineering 1320 bolt in 9inch irs kit with 3:70 gears Forgeline 3 piece GX3 20" Rims 275 front Nitto Invo's 315 rear Nitto Nt05r's Oem ZL1 hood with painted carbon fiber insert Daytime driving lights have been replaced with projector sytle to match the headlights and added 5k hid's from Diode Dynamics Color match bowties and tail light bezels Sequential LED Rear Lamps with Rapid Fire and Afterburner Also under the hood as been completely wire tucked and cleaned, I was planning on doing a custom top mount twin turbo setup, ecu and fuse box has all been safely relocated under the cowl by the cabin air filter area. The engine harness has also been modified, originally it would run from the back of the passenger side down to the front of the engine and cross over to the drivers side and run back down.. To clean it up I made the harness run from the back and both sides run down to the front to keep the loom form crossing the front of the engine bay to give it a nice clean appearance. When the original motor was removed the ac system stayed in the car so the factory freon did not escape the system and the ac is still as cold as it was when I bought the car Car has been Tuned and everything went over by JMS after engine install and wire tucked it was dyno tuned and made 505whp The car has been a weekend or once a week to work car, I built the car to take it to the strip but never taken it. the car has been well taken care of, looks and smell brand new inside and out.. Always been in a garage with a car cover when not being driven, I wipe it down every time I drive it and never leave it setting dirty also never been purposely driven in the rain but I have been caught in the rain once or twice. Not looking for trades I know there are a lot of Camaros for sale with more power but most are just an added SC or turbo kit, non have a fully built motor, rear end suspension, fuel system ect. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() If you have any question or want more pictures ( I have a ton ) feel free to PM or text me if you are serious about purchasing, if your not then not to sound like an ass but please do not waste my time. 40k Last edited by 2012InfernoSS; 07-17-2016 at 09:46 AM. Reason: Forgot price |
![]() Drives: 1998 WS6 441 LSX Join Date: Jul 2009
MAY GOOD LUCK WITH SALE BEAUTIFUL CAR! I WANT IT!
1998 25.2 jet stream blue metallic Trans/Am KFP Racing
2001 procharged ws6 408/f1-A KFP Racing 2012 ram 3500 dually triple black cummins 24" American force 2013 ZL1 1993 FOBRA MUSTANG 427 LSX TWIN TURBO/4L80 BUILD |
![]() ![]() Drives: 2011 2SS Join Date: Jun 2013
Where did U move the abs module to it looks very clean now I am considering moving my fuse box also I love how clean it is when it's done
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
ttt
#6 |
TTT
#7 |
bump
#8 |
ttt
#9 |
TTT Price drop 45k
#10 |
ttt
#11 |
To the top
Sent from my ONE A2005 using Tapatalk |
#12 |
Still for sale
#13 |
TtT
#14 |
Added a new braille 18lb battery and some light weight chromoly crash supports.
