01-02-2016, 02:59 PM | #1 |
Drives: 2013 ZL1 Join Date: Jun 2015
More power! (Pushing past 650)
So a few months ago I installed a JRE 650 rwhp package and already toying the idea of trying to get a safe 700-750 rwhp. Is it possible to do that and on 93 octane with stock heads?
01-02-2016, 03:09 PM | #2 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
Without meth, nitrous, ported heads, E85.... if so its rarely done.
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
01-02-2016, 03:46 PM | #3 |
Guess I won't be going any higher then. That all feels like too much work to keep up with
01-02-2016, 04:16 PM | #4 |
Drives: 2014 Camaro ZL1 Join Date: Dec 2014
I dunno about porting the snout & adding a 102mm Nickwillaim tb is gonna add but there is a thread that claimed to gain 50rwhp with dyno graphs , however i saw hell of different opinions on that mod , but you could look into that ....
Lingenfelter 630Hp Package , Afco Heatexchanger , Moroso Catchcan , D3 Tank , Siemens 63Pds/hr Injectors , Custom tune.
01-02-2016, 07:02 PM | #5 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
Its possible but not really "safe".. Don't risk detention when you're at that power level. Use higher octane
Once I started modding my car I felt like it was well worth the price to run a higher octane fuel Just to protect my investment. I ran local 100oct until I made the jump to e85.
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
01-05-2016, 09:00 AM | #6 | |
Drives: 2017 ZL1, A10, White, sunroof, nav Join Date: Apr 2009
I would think ~ 700 could be possible on M6 with similar mods & 93 |
01-05-2016, 05:56 PM | #7 |
M6, I've thought maybe upper pulley (still stock) and maybe heat exchanger or possibly interchiller
01-05-2016, 07:24 PM | #8 |
Drives: ADM TUNED AND BUILT Join Date: Nov 2014
horsepower
01-06-2016, 12:07 AM | #9 |
Snake Eater
nice. No heat soak with spinning the blower past 24,000?
01-06-2016, 12:17 PM | #10 |
I have an auto that puts down 744whp on pump gas. 55,000 miles on it. Trans isn't happy right now but I have put well over 700 passes on it at the strip. I have ported heads and blower though as well as all the other mods, cam 2.55 upper 9.55 lower. Bigger HX and reservoir is a must.
01-06-2016, 04:12 PM | #11 |
Drives: 2011ShelbyGT500 Join Date: Jan 2014
Serious question.
Why not just swap to a bigger blower? Seems like it would be easier/cheaper than doing heads/cams. |
01-08-2016, 11:50 AM | #12 | |
Drives: 1996 Z28/SS, 2013 ZL1 Join Date: Jan 2015
13 Camaro ZL1 IOM #3976
96 SS Camaro #1664, 04 2500 Dirtymax ZL1 Current Mods: KOOKS 2" w/orp, BTR Stage 3 Cam, LPE 2.55, LPE 9.1, ATI Damper, LPE Isolator Coupling, LPE CAI, Ported TB/Snout/Blower, JMS BAP, ID-850, 160 T, Ron Davis HX, D3 Reservoir, Elite Eng CC Gen2... |
01-11-2016, 09:43 AM | #13 | |
This package makes 650 on pump gas and up to 700 RWHP with nothing more than Octane and tuning. Blower efficiency is at the high end of the efficiency map with this pulley combination. You can opt for our 28% crank pulley and race gas and easily crest 720 RWHP on my Dyno. Keep in mind the same car will read different power on different dyno. Many of the dynos read higher than actual. Feel free to contact me directly regarding your next best step toward more power. Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 01-11-2016 at 10:00 AM. |
01-11-2016, 06:11 PM | #14 |
Gearhead
Drives: 2012 ZL1 Join Date: Jun 2014
Ted, what are your thoughts on upgraded heads at this power level?
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip. 11.193@128.13 in 515' DA |
