Old 01-22-2016, 08:05 PM   #1
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
Would you do sub-frame connectors on the Z?
I look at other car sites and these keep coming up so I decided to go to their website. This looks pretty nice. They recommend the tunnel brace to go with the connectors. Would you put these on your car? Thoughts?
Bigtime53 is offline   Reply With Quote
Old 01-22-2016, 08:31 PM   #2
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Tunnel brace is a gimmick. Last thing you need to do is add weight to a heavy car.
Trackman is offline   Reply With Quote
Old 01-22-2016, 08:51 PM   #3
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
Interesting!
I would like to see comments as well.
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 01-22-2016, 09:01 PM   #4
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
No. I would replace the subframe bushings instead. That's what i did on the SS i had and the rear end was much better (replaced most of the rear bushings). The brace is easier and cheaper, but also as stated, adds weight and more places to drag on speed bumbs and curbs. The ZL1 has better bushings and links so i would just start with the subframe bushings and see how it is then.
danvillekidd is offline   Reply With Quote
Old 01-22-2016, 09:36 PM   #5
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
Not for me, that's an old Mustang trick.
To echo what danville kid wrote. I also changed the bushings in the rear cradle when I had the car lowered. The car felt much better when cornering hard, and accelerating after installing them.
ZL1-V is offline   Reply With Quote
Old 01-22-2016, 10:31 PM   #6
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
I have thought about doing what you have done. Are those bushings hard to install?
Old 01-22-2016, 11:26 PM   #7
Nickey31
Nickey31's Avatar
Drives: 2012 Nickey ZL1 #001, 2014 Corvette
I added them because sub-frame connectors were required for an open road race I do twice a year. When I added the sub-frame connectors, I also added a full roll cage so I can't tell you if it is the roll cage or the sub-frame connectors that contribute most to the almost zero body roll I have today.
I know some racers say that the sub-frame connectors are just dead weight. But like I said, I added them to comply to some rules for one particular race.
I have also replaced my rear cradle connectors, all bushings, sway bars, along with 1.5" drop springs and they stiffened things up pretty well. When I bought this car, I very much enjoyed that it drove like a cadillac on the street and like a race car on the track. But after all the mods listed above, it no longer feels like a cadillac. So beware what you think you want. If you want a race car that carves corners, those things will get you there. But if you have a lot of fillings in your teeth, be ready to knock a few out. OK, maybe that's a bit of an exaggeration, but hopefully depicts a picture to give you an idea of how stiff the car becomes.
Nickey31 is offline   Reply With Quote
Old 01-23-2016, 10:12 AM   #8
Masterzl1
Masterzl1's Avatar
Drives: 2013 Zl1 red
you could add the convertible brace to the unibody frame under the car, the nuts are already there just need brace and bolts.
Masterzl1 is offline   Reply With Quote
Old 01-23-2016, 04:28 PM   #9
ZL1-V
ZL1-V's Avatar
I think there are several "how to" posts still here in the archives. It will take you several hours. The hard part was/is removing the stock bushings. Some use heat, but there are other ways of removing them. I used a reputable shop that had done them on other Camaro cars before mine were done. Front and rear were done, so I needed an 4 wheel alignment, so I chose them to do all the work.
Old 01-23-2016, 10:51 PM   #10
RankSS
Drives: 2010 Camaro SS
Hey is that the GRR in your signature photo?
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 01-23-2016, 10:58 PM   #11
ZL1-V
ZL1-V's Avatar
Good catch! Yes it is, about 11 miles up the hill from my house. It's also used in the Amgen Tour of California. Here is one of my shots from the 2011 race!
Old 01-23-2016, 11:43 PM   #12
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
I've done my full suspension, hotchkis subframe brace, pafdt springs, tie rods, trailing arms, sub frame bushings and sway bars. Only thing left stock was the MRC shocks. If I had to do it again it would only be the rear sway bar and the springs, that's it. The biggest waste of money was the subframe bushings and the hotchkis brace. So my advice is save your money and do something else with it like good sticky tires. Toyo R888's or Michelin PSS. (BFG Rivals suck on our cars)
GM did right in this area for this car, i wouldn't change much if I could do it again. I've done two seasons in autocross (the first mostly stock, the second not) and several HPDE events. Just don't want anyone else to waste their money on stuff that doesn't do much, so unless it's required to meet some regulations of whatever event your participating in then skip it.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
