![]() Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
ENGINE TEMPS AFTER OIL COOLER DELETE QUESTION?
I have a 2010 2SS/RS with only 12000 mi. on the clock that has a small oil leak where the oil cooler casting bolts to the block. I have tightened the two mounting bolts a little tighter, but the leak is still there. The car is out of the factory warranty so it is up to me to fix it or just put up with it.
I did confirm that it is leaking from the gasket & not the freeze plug in the end of the casting & that would be an easy fix just replacing the gasket, but I am now thinking of just removing the cooler & the coolant lines to it eliminating any future leaks. My question is, after you removed the factory oil cooler are the engine oil temps staying close to where they need to be in the 210- 220 degree range for a daily driven car? Also, what tool did you use to remove the threaded fitting in the side of the block that you need to plug that is used for the coolant supply to the cooler? Thanks SO MUCH in advance for your help. ![]() ![]() ![]() All The Best Orange 2010 Camaro |
![]() Drives: 2012 2SS/RS LS3 Join Date: May 2012
I removed mine about a month ago and my oil temps are exactly the same (just above 200 deg). I used some pliers to get the fitting out of the block. It was a little difficult to remove due to the tight space. I did a little write up on it a few weeks ago. I would say go for. I removed mine due to coolant leak at the said fitting you are referring too.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G Last edited by TXM62SS; 01-29-2016 at 10:18 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Ford SVT Raptor SuperCrew Join Date: Jun 2011
Link to his write up: http://www.camaro5.com/forums/showthread.php?t=434875
Phoenix (sold)
2014 Ford SVT Raptor SuperCrew How to hug your camaro Buy the car that you would most like to get beat in. The other guy will always be faster. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Does the oil heat up as quickly as it did before removing that cooler?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
Unfortunately it does not for me. I was hoping it would but no such luck.
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
#6 |
Thanks for the answer. Might not do this then unless mine starts to leak
2010 2SS/RS
#7 |
![]() Drives: 2010 SS RS Join Date: Jan 2015
I'm pretty sure that the oil temp gauge is not accurate. It is basically an estimate done by the computer based on rpms and speed not an actual temp reading. The temp displayed is estimated based on the stock system. So removing the oil cooler or adding an aftermarket one probably won't change what the factory gauge reads.
Stainless Power Longtube headers, off road mids, stock H pipe, flowmaster mufflers, Vararam tune model intake, NightFury cam, and 91 octane email tune from Dynosteve @ rdpmotorsport.com. 473 rwhp and 430 ft. Lbs. @3,235 ft elevation.
#8 | |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
The factory piece is actually more of an oil heater than a cooler. Mine has been off for a year now.
The factory piece is designed to heat the oil up quickly for emissions purposes.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#10 | |
If it is a calculated amount based on engine rpm and the cars speed then wouldn't deleting the stock cooler/warmer not cause a difference in the reading of the stock gauge?
2010 2SS/RS
#11 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Other cars don't even have factory oil coolers, the G8 for example.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Or most corvettes.
Nick
Corvette Z06 -1200ish rwhp |
#13 | |
2010 2SS/RS
#14 | |
![]() ![]() ![]() It will also clean up some of the clutter on the drivers side of the engine! All The Best, Orange 2010 Camaro |
