Old 01-31-2016, 06:22 PM   #1
SnowyCamaro
SnowyCamaro's Avatar
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox
DIY: Beltronics/Escort home-made hardwire and permanent mount
I have kindof a unique way of mounting my radar detector and i thought I'd share. Plus this will explain how you can use any house hold telephone wire for power.
(This works for my sti magnum, i cannot guarantee it will work or wont damage your detector)
First off here is a picture of the final product.
The first thing you will need to do is make your power harness. Take your standard telephone cable. Try to use a higher quality cable. The cheap ones are hard to strip cause the wires get really thin. There are 4 wires in most. You only need to use 2 of them. The 2 center pins are used for ground and power. And it is the opposite of what you think. Green is positive 14.4v switched power and red is the negative. This is just how it works out. MOST telephone cables should be similar. Double check the pin locations using the picture of my cable below.
I took this cable and added a spring to it that way i could tuck it away when i dont have the detector up. The reason being i dont use it in the city. I took a standard magnet you can pick up at just about any hardware store and stuck it to glass so i can lay the wire out of sight.
I then attached the "permanent mount" from ebay. I have these in both my cars and love em. They come with 3m tape and just stick onto the windsheild. The 3m tape comes off pretty easy and you can use a razor blade and goo gone to get rid of any residue. (I removed my last one from my old camaro).
Now run your cable inside the front of headliner over to the a pillar and down inside the weather stripping to the fuse panel. Where we will find switched power.
SnowyCamaro is offline   Reply With Quote
Old 01-31-2016, 06:23 PM   #2
SnowyCamaro
Next finding switched power. First you will need a fuse tap and an appropriate fuse. I used 5Amp because i plan on running future lighting off this same circuit. But if you plan on using just your rd i would go with 1 or 2 amp.
I also like to wire this up with a switch for convenience, but that is up to you.
There is good switched power on the P18 circuit.
Remove the fuse and insert it into your fuse tap. Make sure the 20A fuse is still the main fuse for the circuit.
In order to fit the fuse tap into place you will need to remove the trunk relay and trim the plastic as shown. I used side cutters but whatever works for you.
Now install the fuse tap and then the relay back into place, you will have to bend the fuse tap a little bit. It's a snug fit.
Check with circuit tester for power.
I installed a switch under the dash by drilling a 1/2inch hole and mounted a rocker switch.
Then i used the large 13mm bolt as ground
Hook everything up and it should power your rd.
I like putting quick connects on everything including the telephone cable, then everything is clean if i have to take everything apart later. But thats just me.
Old 01-31-2016, 09:42 PM   #3
grahak2
Drives: 2021 scatpack challenger 6spd cinna
Hi SnowyCamaro,
Real professional looking job! Thanks for the write up. I followed what you did but a little too much for me. I haven't ever drilled into the car or removed panels and messed with circuits. I envy the guys that can though.
Thanks a lot for taking the time to post this for those that want to give it a try. And still interesting for us non mechanical guys too.
Kevin
grahak2 is offline   Reply With Quote
Old 02-01-2016, 09:26 AM   #4
hazy
Drives: 2011 2SS/RS
well done. I'm going to be stealing a few of these ideas.
Any reason you didn't just tap into the power on the mirror?
hazy is offline   Reply With Quote
Old 02-01-2016, 11:52 AM   #5
SnowyCamaro
Mainly because of how the wire hangs. It didnt look as clean to me. And adding a fuse up there is really ugly unless you have a nice little inline one. I was in need of power for lighting as well anyway and there should be lots of room on power socket circuits.
Old 02-01-2016, 11:54 AM   #6
SnowyCamaro
It should be noted that on this install i had to make a ball of tape (similar to how you would tape a hockey stick) on the cable to essentially wedge the cable up in the head liner. Or else it would fall out. But i didnt have to do this on my 1lt. So its all dependant on how your headliner fits i guess.
Old 03-29-2017, 09:09 PM   #7
macnroxy
Drives: 2015 2ss
fuse panel in trunck
I am installing amps in the trunk is there a good circuit to tap into (remote on/off) in the panel that's in the truck so I don't have to run the wire through the cabin?
macnroxy is offline   Reply With Quote
Old 09-03-2017, 06:24 PM   #8
SnowyCamaro
Missed this, if you haven't done it yet. There is a fuse panel in trunk that you likely can find switch power. If I remember right the fuel control module circuit is like 25amp, should be able to tap a circuit off that maybe. I'd try to find a less "critical" circuit in there though.
The Boston acoustics stereo has an amp back there and there is a trigger wire you can use fed into that harness. Not sure about the non ba stereos.
Sent from my XT1563 using Tapatalk
Old 09-29-2024, 08:09 PM   #9
crazyhorse
Drives: 2013 2SS Camaro Automatic
using number 18 on a 2013ss worked perfectly for AEM 30-0334 Air/Fuel OBD2 power source with a fuse splitter and a 5a fuse they said to use
THANK YOU!!!
crazyhorse is offline   Reply With Quote
Old 10-01-2024, 06:50 PM   #10
dkp2LT
dkp2LT's Avatar
Drives: '11 2SS, '11 C6 GS, '04 MDX
I use Uniden R6's for my Camaro & Corvette. For my daily driver I use an R7. I added an Escort M version dash cam in all three. For the Camaro and Corvette I simply tapped into the mirror power/ground using pins. For my daily, an old Acura MDX, I did have to do a bit more work.
(For the Camaro I also replaced the rear view mirror with one that has a screen for the rear cam).
Your solution is high quality work, but I'm wondering if there are any advantages over simple taps?
dkp2LT is offline   Reply With Quote
