Old 02-14-2016, 02:31 AM   #1
Austyn
Drives: 2000 Camaro Convertible V6
Newbie needing some help
What could cause a 2000 Camaro V6 to smoke from under the hood, have extremely high oil pressure, and a normal temp range? The pressure jumped up to 120+ while the temp stayed at 190-220 the whole time.
Austyn is offline   Reply With Quote
Old 02-14-2016, 10:42 AM   #2
Corp Z
Drives: Camaro
Lots of things could cause it too smoke. Is it in fact smoking? Or is it steam. Remember that the temp gauge on post 97 or 98 fbodies is essentially an idiot light and wont show temps past half until the check gauges light comes on.
Also has the engine been overfilled with oil? Check the level and report back. Also look for oil in the coolant overflow bottle. This could indicate a more serious head gasket or block issue.
Corp Z is offline   Reply With Quote
Old 02-14-2016, 10:52 AM   #3
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Sounds like a head gasket to me.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 02-18-2016, 05:23 PM   #4
Tenring
Tenring's Avatar
Drives: 2014 2SS/RS - SIM
My guess also
Tenring is offline   Reply With Quote
oil pressure, oil temp
