Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 03-24-2016, 12:14 PM   #1
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Car hauler questions
I figured this sub forum would be appropriate to ask these questions since most of y'all haul to tracks. I just got my new truck and am thinking about a car hauler to do some events without risk of getting stuck far from home and giving the camaro a break. What length hauler do y'all recommend to keep tongue weight down to 600-800lbs? 16',18',20'? 6000lbs trailer/car @10-15% tongue weight. I've been looking at big Tex and pj trailers with treated wood boards. Not looking to spend more than $2500.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 03-24-2016, 09:44 PM   #2
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I have a 16' trailer. Tongue weight will depend on where you place the car over the axles. My axles are slightly rearward of the trailers center so the car sits back a couple feet from the front. Biggest thing I think would pose a problem is trailer width, the car it pretty wide. I think my trailers is 79" wide and I have about 2" to spare on each side.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 03-24-2016, 09:53 PM   #3
jrhagen
Banned
Drives: Camaro
18' with 3' dove tail. Get ramp extenders or you will drag the front bumper when loading and offloading.
jrhagen is offline   Reply With Quote
Old 03-26-2016, 03:56 AM   #4
X25
X25's Avatar
Drives: '16 C7 Z51
From my build thread (11-22-2015):
Originally Posted by X25 View Post
UPDATES!
Just picked up the new trailer! Observe how low it is. The height + tilt feature will help make it much easier to load the cars.
The 10"x30" approach plates. The driver side fender is hinged,.
Ultra Type 62 Trailer (alloy) wheels. 6 lug design increases its load capacity to 2800+ lbs!
Tilt in action.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 03-26-2016, 11:36 AM   #5
AG1LE
AG1LE's Avatar
Drives: '14 1LE
From my build thread:
What are the trailer specs (width, length, weight)? I didn't see these in your thread, sorry if I missed it. Thanks
AG1LE is offline   Reply With Quote
Old 03-26-2016, 01:39 PM   #6
X25
X25's Avatar
Drives: '16 C7 Z51
I am not sure if I posted them anyway. These are built here in WA state, and the price is actually pretty affordable. I customized it a bit with different tires, wheels, cross-bar spacing, etc., but here are the specs of the base model:
http://www.trailerrep.com/images/doc...pricesheet.pdf
...(2) 4” Drop EZ-Lube 3,500 lb Brake Axles, HD 5" x 2" Box-Tube Frame, HD Box-Tube Tongue, X-Tra
Wide 84” Deck, Straight Deck, Emergency Break-A-Way Kit, 2 5/16” Coupler...
Options are also affordable, and are listed here:
http://www.trailerrep.com/index.php/...d-options.html
In short, it is true 84"-wide deck, which allows carry a very wide car like the Camaro.
Old 03-26-2016, 01:52 PM   #7
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Thanks X25 - is yours the 16.6ft?
Old 03-26-2016, 01:54 PM   #8
X25
X25's Avatar
Drives: '16 C7 Z51
I think tilt beds start from 18ft; I do have the 18ft model. I loaded Camaro on my former 16.6ft flatbed trailer before switching to this one, and it was barely long enough to properly load Camaro.
Old 03-27-2016, 02:02 PM   #9
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
18ft steel deck (2ft dove) with etrack bolted down to strap the tires down to the trailer and home made rock guard
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 03-28-2016, 05:09 PM   #10
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
ACKEIGHT;thanks for this thread. I'll need this info after income tax return...hopefully.
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 03-29-2016, 12:00 AM   #11
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Thanks for the picture. It really is worth a thousand words. Most of the trailers i've looked at online are 18' dovetails. How long are your ramps? I've seen some with 4' and 5' ramps. I would think the 5' would be easy to load without high centering. The 4' has me nervous.
Old 03-30-2016, 12:13 PM   #12
SSGrant
SSGrant's Avatar
Drives: 2011 2SS 6 speed yellow
I would say do the 5' ramps for sure. Would rather them be longer than to short. 18' deck is the shortest I would go. And definitely check the width between the fenders. Here's my trailer I use. Have fun!
SSGrant is offline   Reply With Quote
Old 03-30-2016, 07:21 PM   #13
rockrau
rockrau's Avatar
Are there any issues opening the drivers door contacting tires or fender on a
lowered car?
Old 03-30-2016, 07:25 PM   #14
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
Get an 18 footer at a minimum. Gives you room to mount a tool box, tire rack, etc. I've owned an H&H 18' tilt bed dovetail for 15 years and it's still a great trailer despite a ton of abuse. Also spring for heavy axles and get an equalizer hitch if the tongue gets heavy or your truck sags (safety first). Long ramps a must for low cars.
Sent from my iPad using Tapatalk
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
