Old 04-09-2016, 11:29 PM   #1
carlosdmartins
To help and to be helped!
Drives: '15 Camaro 1LT/RS, Black/Gray
Resonator delete... which way to go?
Hi there guys.
I have a '15 1LT/RS and Inwant to remove that big ugly box that's called resonator.
2 questions, what is the diameter of the pipes and which aftermarket resonators you guys recommend?
Thanks in advance for your help guys.
carlosdmartins is offline   Reply With Quote
Old 04-10-2016, 03:23 AM   #2
SinginHawk
SinginHawk's Avatar
Drives: 2015 2LT
2.25" pipes, Magnaflow Resonated X-Pipe (or not resonated if you want more volume and don't mind drone).
2015 2LT Cosmetics: ZL1/1LE Wing Spoiler, SS Carbon Hood, Z/28 Carbon Diffuser, SS Front Bumper, RS Taillights, 1LE Carbon Splitter, Phastek U-Halo Headlights, Fade-to-Black Gills
Performance: ZL1 NPP Exhaust, ZL1 6-Piston Brakes, ZL1 10-Spoke Wheels, Nitto NT555 G2 295/35/20 x 4, Magnaflow X-Pipe, Blackvue DR650S2-CH Dash Cam
SinginHawk is offline   Reply With Quote
Old 04-10-2016, 09:38 AM   #3
shags
shags's Avatar
Drives: 2016 SS Garnet Red A8
Xpipe
Muffler/secondary cat delete , blacked out bowties, blacked tails and marker lights, graphite dipped wheels, drop in filter so far!
shags is offline   Reply With Quote
Old 04-10-2016, 10:13 AM   #4
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
That resonator is for the automatic
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 04-10-2016, 10:15 AM   #5
carlosdmartins
Originally Posted by shags View Post
Mine doesn't have resonator like that ..and it's a 2025 rs strange
I have 1 bullet style resonators on each side
Do you have the dual exhaust system?
Mine has it. It's that system that when you get on the gas the flaps open, I dont know if it has anything to do with it.
Old 04-10-2016, 10:18 AM   #6
chasmanian
chasmanian's Avatar
Drives: 2015 Camaro SS
The resonators are the two smaller ovals towards the back. The big thing behind the cross brace is the h pipe.
chasmanian is offline   Reply With Quote
Old 04-10-2016, 10:19 AM   #7
carlosdmartins
Hmmm.... Interesting. My buddy has the same exact car has mine and removed the box (pictured) and put 2 straight pipes . That thing when the flaps open sounds like an import. It sounds rice.
Old 04-10-2016, 10:19 AM   #8
chasmanian
chasmanian's Avatar
That's not what my resonators looked like and I have an automatic
Old 04-10-2016, 10:20 AM   #9
chasmanian
chasmanian's Avatar
You're not looking in the right direction I the pic I don't think
Old 04-10-2016, 10:20 AM   #10
shags
shags's Avatar
Yeah you have the npp exhaust. . Resonated xpipe and you're golden or delete all together sounds good on the npp
Old 04-10-2016, 10:22 AM   #11
carlosdmartins
And what can I replace that with?
Old 04-10-2016, 10:24 AM   #12
shags
shags's Avatar
Magnaflow resonated xpipe. . In place of the suitcase resonator you have now. Would be your best bet
Old 04-10-2016, 10:25 AM   #13
carlosdmartins
Maybe you're right. This "box" pictured is located towards the front of the car.
Old 04-10-2016, 10:26 AM   #14
shags
shags's Avatar
No man you are right that's your resonator the 2 small ovals are on your down pipes those are cat's. . The thing in the middle is what you would want to replace
