Old 04-11-2016, 10:34 AM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Transporting on a Uhaul Hauler
Has anyone transported a SS camaro on a car hauler from uhaul. I am afraid of the ground clearance while pulling up the ramps
zz430camaro is offline   Reply With Quote
Old 04-11-2016, 10:48 AM   #2
Motorboy8769
Drives: 2015 2ss
I'm not sure of the height of the u haul deck I haul mine on a open trailer. Just jack the trailer up as high as you can while hooked to the truck. Have someone watch and go slow if the plastic piece hits stop and try maybe some 2x10 or 2x12 maybe a 5-6 foot piece to "extend" the Ramps. If you know what I mean. With the wood you should be fine if you jack trailer up and use the wood I think it will go on fine.
Motorboy8769 is offline   Reply With Quote
Old 04-11-2016, 11:35 AM   #3
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
I've done it a couple of times. My driveway is angled but flat on the top. Backed up so the ramps were flatish. Then I had to put 2 x 10 under the front tires to clear the lip of the trailer. I'm lowered about 1.5 inches. Car towed really well once all was done.
mp51998 is offline   Reply With Quote
Old 04-11-2016, 12:57 PM   #4
flyer08
Drives: 2010 2SS/RS
Done it multiple times with lowered car and stock car. On stock height the issue was getting the car back off as the air dam under front was rubbing. Lowered car doesn't have it, been removed.
flyer08 is offline   Reply With Quote
Old 04-11-2016, 01:14 PM   #5
Welker2
Ret AF, cancer survivor
Welker2's Avatar
When I had my Callaway Corvette, I transported it a few times on a uhaul with no problems; it was lowered, had a body kit & sat extremely low...I would guess much lower then your SS
Old 04-11-2016, 02:38 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You can always back the truck onto some 2x10s so the back of the truck sets up higher while pushing the tail of the trailer closer to the ground.
Orange Krush II
