Old 04-11-2016, 06:10 PM   #1
rydahog
rydahog's Avatar
Drives: camaro ss
tires inside camaro..
Will 4 base camaro tires on rims, fit inside a camaro for transporting them.? Thanks
rydahog is offline   Reply With Quote
Old 04-11-2016, 06:15 PM   #2
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
They should. I've fit 20x10.5 with 285/35 inside the car before. Needed the passenger seat though.
Jenner is offline   Reply With Quote
Old 04-11-2016, 06:50 PM   #3
rydahog
rydahog's Avatar
Drives: camaro ss
yes,,,i was thinking one trunk....2 in back seat area...and 1 in pass seat...does that sound right?
Old 04-11-2016, 06:53 PM   #4
speedzalot
speedzalot's Avatar
Drives: 2011 Camaro SS
I don't think you can fit 1 in the trunk with tire mounted , the trunk opening is small .
speedzalot is offline   Reply With Quote
Old 04-11-2016, 06:54 PM   #5
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
I did just that a while back , two 20x9 in individual boxes on the trunk , I had to put it through the back seat , ten close the seat back up to its normal position
Then I put the Oder two in their boxes also on the read seat , then we went in to a 200 + miles one way drive
Jackass is offline   Reply With Quote
Old 04-11-2016, 07:00 PM   #6
rydahog
rydahog's Avatar
Drives: camaro ss
tires in rear?
HI,,i need to know with rims and tires? will they fit? thanks no boxes//
Old 04-11-2016, 07:23 PM   #7
BLU DUCE
BLU DUCE's Avatar
spike III Build IBM 1SS/RS [COTW] 6/25/12
Yes you can I put a full size spare in the trunk every time I go out of state.
Old 04-11-2016, 07:50 PM   #8
Mcgin014
Drives: 2014 Camaro
I had 4 tires shipped to my house 2- 245/45/20 and 2- 275/40/20 in the car with a set for sway bars and front and rear brembo brakes calipers and rotors. All in the trunk and back seat folded down.
Mcgin014 is offline   Reply With Quote
Old 04-11-2016, 07:55 PM   #9
chevyracingfan
chevyracingfan's Avatar
Drives: 2018 camaro ls 1le
they will fit feed one into trunk thru back seat area .I fit 4 19 inch and extra spare without using front seat
chevyracingfan is offline   Reply With Quote
Old 04-11-2016, 08:12 PM   #10
WeflyhereSS
WeflyhereSS's Avatar
Drives: 2012 Black on Black Camaro 2ss
Dope question I'm getting mrr 228 n a few days and need to transport to tire shop put on thanks guys
"How do u keep it under the speed limit? YOU CANT HAHAHAHA"
WeflyhereSS is offline   Reply With Quote
Old 04-11-2016, 09:59 PM   #11
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Yup, when I bought mine in California, drove back to AZ, folded down the back seat, and loaded up a carry-on suitcase, two 285/20's a stock air box, car cover, and still had room for another tire.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-11-2016, 11:31 PM   #12
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I was able to transport 4 Blizzaks in my car to the shop for install.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 04-12-2016, 07:27 AM   #13
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
They fit. I had one on the trunk 2 in the back seat and one in the pass seat.
Thor142 is offline   Reply With Quote
Old 04-12-2016, 09:29 AM   #14
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
If you're over 6' tall its pretty comical . My friend bought 4 snow tires for his RS last year . With all 4 tires in the car and the 2 of us I ended up driving because he couldn't fit behind the steering wheel . I was laughing my ass off .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
