Old 04-19-2016, 09:02 PM   #1
The_Driver
Banned
Drives: 2015 Camaro 1LS M6
Question Can I switch the tire sidewall around without rebalancing the whole wheel?
I was driving along when I came upon a road that was being prepared for asphalt. They rough graded it down to the base grade level, but they left a stupid 1" ledge of old asphalt near the right lane. I inadvertantly drove near the ledge and my right front tire got slightly scraped just below the tread area on the sidewall section. I tried to burnish the rubber and it did make it less noticeable, but I can still see the scratches in the rubber.
Is it possible to flip the tire around on the rim (inner sidewall now facing outside) without having to rebalance the whole wheel again? I'm thinking that if tire shop marks where the tire is in relation to the rim, they can flip the tire around and I won't have to rebalance the wheel.
Thoughts?
The_Driver is offline   Reply With Quote
Old 04-19-2016, 09:16 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Flipping a tire on the wheel will still need to be re-balanced. The tire shop flipping the tire should balance it without question.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 04-19-2016, 09:44 PM   #3
jrhagen
Banned
Drives: Camaro
Shouldn't matter on a V-6.
jrhagen is offline   Reply With Quote
Old 04-19-2016, 09:59 PM   #4
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
If they have the wheel off the car why not at least check the balance before putting it back on?
Are you trying to save ten dollars or something?
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 04-20-2016, 06:37 AM   #5
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
Also make sure they aren't "directional". Most probably aren't, but my non-stock ones are.
Jim
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 04-20-2016, 09:05 AM   #6
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
I would definitely have them rebalanced, otherwise you'll get vibrations and uneven tire wear.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 04-20-2016, 09:17 AM   #7
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS
Are you trying to be a dick? Or are you just that simple minded?
colingordon is offline   Reply With Quote
Old 04-20-2016, 09:27 AM   #8
MIMZL1
MIMZL1's Avatar
Drives: 2014 ZL1 Camaro #0001
If you remove the tire and flip the tire around you will need to rebalance the tire/wheel assembly. The tire has a three dimensional balance and is not totally uniform (i.e. different side wall flex from side to side around the tire, etc). The same 3 D balance issue is true of the wheel (usually to a lesser extent though). OEMs usually match balance and road force balance a tire/wheel assembly. Flipping the tire around may cause a small vibration or a very harsh one so I would rebalance and do a road force measurement on the assembly.
MIMZL1 is offline   Reply With Quote
Old 04-20-2016, 09:36 AM   #9
Denis
Denis's Avatar
Drives: 2010 SS
you're either being an ass or ignorant. Neither is a valid excuse.
like others have said, gotta rebalance everything. it doesn't cost much to do it right the first time.
Old 04-20-2016, 09:36 AM   #10
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Since he has nearly 1200 posts, I'd vote for dick......stopped being funny a long, long time ago...
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-20-2016, 09:56 AM   #11
jrhagen
Banned
Drives: Camaro
Answering a dumb ass question with a sarcastic response.
Old 04-20-2016, 10:01 AM   #12
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
It wouldn't matter on a SS either with a square setup .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 04-20-2016, 10:09 AM   #13
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I thought it was rather funny ...
Old 04-20-2016, 11:42 AM   #14
colingordon
Her Name is Mila
it may be a dumb question to you, but not to others. I have no problem with the question, cause I would rather him have it done right than for him to hurt himself or others.
Oh, and I wouldn't get to cocky cause I am sure you have plenty of questions I would consider a "dumb-ass question" that I could respond to with a "sarcastic response"
Internet trolls...
