05-15-2016, 03:58 PM | #1 |
Drives: 2023 Camaro 2SS 1LE Join Date: Sep 2015
2nd Gear Grind
How it going guys? I'm new to driving manual and today at WOT I sifted into 2nd and there was a loud grinding noise I looked down and saw the tranny had popped out of 2nd. What do you guys think caused this my thought Is that I hadn't put the tranny in 2nd gear fully and let go of the clutch also how much damage do you guys think it caused ? I drove the car for about 15 min after and everything seemed fine. thank you guys for all your help
05-15-2016, 04:04 PM | #2 |
Drives: 2010 2SS Camaro 6sp. Join Date: Jan 2012
You missed a gear. Shifted to late or hesitated while shifting.
05-15-2016, 04:08 PM | #3 |
05-15-2016, 04:15 PM | #4 |
Yes if you keep doing it.
05-16-2016, 08:57 AM | #5 |
Drives: 2011 2SS/RS Join Date: Feb 2014
it's a known thing with the TR6060 in the M6 SS models.
Once the trans is up to operating temp, you should be good, but you'll probably get a good grind if you try and bang on it while it is still cold. Just search this forum for "2nd gear grind" and you'll find a myriad of "fixes" some of which are as simple as letting the trans warm up, others involve an additional clutch fluid cylinder, upgraded clutch master cylinder, or replacing the trans fluid with something other than what the factory provides. There are also options for rebuilding the trans with some upgraded parts, but that shit starts getting $$$. Me? I just let the transmission warm up before getting too rowdy on my shifts |
05-16-2016, 09:35 AM | #6 |
Drives: 1LE Join Date: Feb 2013
The grinding is only a "known issue" on the 2010s and 2011s. His 2015 is likely fine. Though, I will admit that even the new ones are stiffer when cold, and the fluid/reservoir issues probably do make them smoother.
I suspect he missed the gear, also. I've done this once while trying to drive the car gingerly when cold -- I simply didn't get it all the way into 2nd and it popped out. No grind, but I suspect it would have if I was getting on it. Scared the poo out of me, as I've had past cars where this was an indicator of a real mechanical problem. But, thousands of shifts later, and it never happened again. OP, it is highly unlikely you hurt the car doing this once. |
05-16-2016, 09:36 AM | #7 |
My 2011 does that and in my case its the syncros going bad.
05-16-2016, 09:50 AM | #8 |
KaBoom1701
Royal purple.....never looked back.
Mods:
05-16-2016, 09:55 AM | #9 |
Hmmmmm whats that old saying again. Im sure youve heard it at least once
You cant find it. Then grind it Letting the trans warm up is a big yes. Thays why I ll let my car warm up for a few before heading out.
05-16-2016, 10:18 AM | #10 |
Drives: 2015 2ss Join Date: Jun 2009
same issue i found after buying my '15 new. Just let the trans warm up. Hopefully you just missed a gear, but if it continues to pop out of gear contact Chevy for warranty work.
2015 Camaro 2ss, NicKey Performance built/tuned |
05-16-2016, 01:11 PM | #11 |
Thanks for all the input guys. The cars going to go to the mechanic shop to get LTH installed ill have them change the transmission fluid also. I was shocked when it happened I hadn't experienced a noise like that it felt like it lasted for 2-3 seconds. I learned from my mistake.
05-16-2016, 01:15 PM | #12 |
Drives: C6 Corvette Join Date: Sep 2013
Granny shifting not double clutching like you should.” – Dom Toretto
--interesting hearing about this issue. I've never had it on mine when cold or up to temp
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
05-16-2016, 01:15 PM | #13 |
Drives: 2011 Camaro SS Convertible Join Date: Nov 2015
Start off in 2nd gear until the car warms up.
05-16-2016, 02:56 PM | #14 |
Nooooo you will trash your clutch! Just let the car warm up for a few and thats it.
Truck drivers do that in there commercial Vehicles. I know. Im one.
