05-19-2016, 04:50 PM | #1 |
Drives: 2011 1LT Join Date: Mar 2012
TPMS question
Yesterday, my dashboard lit up with instruction to get my TPMS serviced soon... and it appeared that there was no reading coming from my rear/ driver tire. After clearing the message, my little "flat tire" light was illuminated on my dash (guess I should carry a roll of electrical tape with me, to cover up annoying lights!).
After a start and a restart, though, all seemed good... the questionable tire even displayed correct pressure. Buuuuut.... a few minutes later, it all happened again. Today, though, all day, the dash has been calm and not illuminated with warnings (no, I did not cover anything with electrical tape). I'm ASSUMING that with the problem being intermittent, it may be a battery issue... or, maybe something else has gone wrong. Yep... it's one of those two things. My questions are: Do the sensors have batteries in them? Do I need to replace a battery? Or, is it just cheaper/ easier (you may have already guessed that I am cheap!) to replace a sensor? Should I replace all four, if I'm doing one (my rig is almost six years old now)... are they an item that generally has a shelf life? If I decide to replace it, will any tire shop have a giant box of them on hand, or should I purchase one ahead of time, and carry it to the shop (I'm due for tires in the next month or so, and I plan to make necessary changes/ repairs then)? |
05-19-2016, 07:56 PM | #2 |
Drives: pleather and Chiclets Join Date: Mar 2012
Replace the whole thing.
No reason you or the shop can't get them.
05-20-2016, 03:47 AM | #3 |
have all of them replaced with your new tires. being a 2011 they lived there lift and there batteries are dying. you can buy the GM ones cheap online. part number 13581558 http://www.amazon.com/ACDelco-135815.../dp/B00O9H0QIG
05-20-2016, 10:27 AM | #4 |
Thank- you for your responses!
05-20-2016, 04:42 PM | #5 |
I would first try to relearn them if that doesn't work definitely replace them
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
05-21-2016, 01:51 PM | #6 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
Yeah sounds like the batteries have given up the ghost or maybe just went defective. I can get you any quantity you need.
Rudy |
