05-25-2016, 06:21 PM | #1 |
AC question...
I've had my 2014 2SS for almost 6 months now. Weather is definitely getting warmer so I am using the AC more and more. It works perfect but I have a question that is bugging me...
I've read the manual, and I've done searches but I can't seem to get an answer: What exactly is the "Auto" mode that shows sometimes when the AC is turned on? I say sometimes because there seems to be no rhyme or reason as to when it shows the "Auto" mode and thus the "Recirculate" without having first pressed the recirculate mode.
05-25-2016, 06:53 PM | #2 |
Hmmm... I have not noticed this, but as the manual states: "To improve fuel efficiency and to cool the vehicle faster, recirculation may be automatically selected in warm weather. The recirculation light will not come on".
Sounds like there is a temperature sensor that automatically puts the AC in "recirculate" mode temporarily to cool the cabin more quickly. I'll have to pay closer attention and check it out.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
05-26-2016, 05:39 AM | #3 | |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
05-26-2016, 05:53 AM | #4 |
Drives: 2013 ZL1 M6 Convert Triple Black Join Date: Feb 2014
Where in SC are you from?
05-26-2016, 07:37 AM | #5 |
Drives: 2014 2SS/RS Join Date: Jan 2014
Hmmm...
I'll believe that the system will go in and out of Recirc on it's own, but I've never seen this, since it doesn't display the mode change when the system does this. I'm not so sure about the system changing the fan speed to maintain a set temperature. I have always thought that these are pretty much manual systems, rather than maintaining a "set" temperature. In my experience, the A/C will pretty much run all the time, and the inside temp is regulated by adding the amount of heat dialed in by the rotating knob. I've had my SS since March of 2014, but to tell the truth, haven't really played around with the A/C too much. I operate it as I've described above, noticing that if I don't tweak the "Temp" knob up a little on a longer drive, it will freeze me out. That's my story, and I'm stickin' to it :-)
05-26-2016, 07:58 AM | #6 |
You can set the A/C to a certain temp?
05-26-2016, 08:32 AM | #7 |
You set the temp by adding heat. I always have mine set to max cold. I do not like auto temp systems as I want control of my fan speeds.
05-26-2016, 08:41 AM | #8 |
Several late model HVAC systems have actual temperature settings one can set in an "auto" manner. What I was referring to is the original quote stating one could set the A/C temp to maintain. Obviously it is clear we can change the temperature using the temperature dial. But how is one to know what temp? I do not believe our 5th gen Camaros have that capability.
05-26-2016, 08:54 AM | #9 |
Drives: camaro Join Date: May 2016
05-26-2016, 07:45 PM | #10 | |
Not far from you... I'm in Greer, not far from Hwy 101.
01-15-2023, 01:08 PM | #11 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
Where did they hide the internal cabin temperature sensor?
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
