06-10-2016, 03:25 PM | #1 |
Drives: 2013 2LT Join Date: Jun 2016
Broke Oil Drain Plug
Just went to do an oil change on my Camaro, bought a torque wrench to do it in the right way, set it to 18ft-lbs... and the oil drain plug broke off at the head. I now have the nut part separated from the male part, which is still in the hole. I have no clue what my next step is.
EDIT before reply: Yay search function. Now to find a way to the auto supply store... |
06-10-2016, 03:28 PM | #2 |
Drives: 2010 Camaro 2SS Bumblebee Join Date: Apr 2016
The ugly truth is that unless you can get the threaded portion of the plug out of the pan, you will have to replace the pan unless you can grab it from inside. Many other may have other solutions, but I think you'll have to remove the oilpan and perhaps replace it.
06-10-2016, 03:29 PM | #3 |
Drives: Camaro Justice Join Date: Jun 2007
EZ out type device. http://www.brokenbolt.com/blog/tag/broken-ez-out/
06-10-2016, 03:29 PM | #4 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
Never seen that happen, usually just strips the threads.
Anyway before you go buying punches, left handed drills and/or easy outs maybe you should take it somewhere or have a friend over that is a little more experienced. Impatience or using the wrong tools here could cost you the oil pan and a lot more money.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
06-10-2016, 03:30 PM | #5 |
Drives: 2013 camaro Join Date: Mar 2013
Sounds like you will have to purchase a screw extracting kit. You can simply find these at lowes or home depot.
Good luck |
06-10-2016, 03:31 PM | #6 |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
I would drill it out... being very careful not to damage the threads in the oil pan.
06-10-2016, 03:32 PM | #7 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
need to use a screw extractor... or EZ Out
basically drill a hole, the extractor has reverse threads so as you screw it in... it will remove the bolt. RIGHTY TIGHTY!! LEFTY LOOSY!!!! |
06-10-2016, 03:33 PM | #8 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
You can 'tap' it out with a special drill bit or take to shop and have it done. Might be a little cheaper & easier then replacing the entire oil pan...good luck
06-10-2016, 03:34 PM | #9 | |
06-10-2016, 03:59 PM | #10 |
wow. you need to check that torque wrench. 18 ft.lbs is very, very light.
maybe it clicked without you feeling it and you kept pulling until it snapped? you've already gotten good advice on how to get the broken bolt out. I'm just trying to keep you from doing it again. there's no way you could've done that with 18 fl.lbs |
06-10-2016, 04:01 PM | #11 |
another idea on getting the bolt out if the EZ out stuff doesn't work (it should)...
weld a flat bar to the bolt, but not the pan, and twist. good luck. |
06-10-2016, 05:10 PM | #12 |
Drives: 2014 2SS/RS Join Date: Dec 2014
WARNING: the Camaro oil pan is aluminum relatively soft and half the melting point of steel, best to have someone with experience remove the remainder of the broken bolt for you, easy task for a pro. It helps to have plenty of work room when the extraction is done to lower chances of making the situation worse.
By the way, the bolt may have been previously damaged before you even started to tighten it; the relatively low amount of torque you put on the bolt should not have caused the head to snap off ... did you see any voids or flaws in the steel at the point it separated? Are you sure you had the torque wrench in the correct plane and turning it with your hands at the correct points on the torque wrench? Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
06-10-2016, 05:12 PM | #13 |
Jus' Cruzin
Drives: 2017 Camaro 1SS Krypton Green Join Date: Oct 2012
Wow, that sucks.. I think an EZ out is your best option.
Just a suggestion, finger tighten your oil pan nut next time, then give it an extra half turn with a wrench. There's no reason to use a torque wrench..
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark |
06-10-2016, 05:28 PM | #14 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
One of the reasons I have a Fumoto Valve. Yes it takes longer to drain but no risk of stripping the threads.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
