Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 07-09-2016, 04:32 PM   #1
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Airbag Deployment when Seatbelt not Latched?
Does anyone know if the SIR System functions any differently if the seat belts are connected or not?
The reason for the question is: when at the track, I run the harnesses with the OEM belts unlatched. If in a wreck, I'd still like the bags to function as designed. I realize that the belt retractor would be ineffective, but that's not a concern because the harness already have you all the way back.
I'm debating whether to install a switch to fool the SDM to think they are connected while at the track.......although I'm not real keen modifying the factory safety items in place.
Apologies if already discussed, I didn't see it in my search
h018871 is offline   Reply With Quote
Old 07-09-2016, 05:16 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
From my understanding, it will deploy the airbags in a slightly different manner and timing, to try to compensate for the driver being unrestrained. It knows you're there in the seat, due to the occupancy sensor.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 07-09-2016, 08:29 PM   #3
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
I've looked at the wiring diagram and read the system description in the service manual. Everything is controlled by the SDM, the manual treats it as a black box. There's no mention of the logic used outside of the impact severity and the driver's seat position.
Thx and I agree with your logic captain, I'd like to think that it is not made inactive if the belt is not latched
Old 07-09-2016, 09:13 PM   #4
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
Instead of a switch, get the insert end of a seatbelt from a junkyard that will fit the Camaro buckle. With it inserted in the buckle the system will think you have the belt on. You can also do a search on-line. There are companies that make an insert you can buy.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
Old 07-10-2016, 08:15 AM   #5
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
When I was reading on Schroths website about their 3 and 4 point connection harnesses for use with factory restraint receptacles they mentioned that an advantage to using their system is since they use the factory receptacles the air bags will deploy at normal rates. If the vehicle doesn't think you are belted in they said the air bags will deploy faster/harder. So it sounds like it would be best to have something to plug into the OEM female receptacle to retain normal air bag deployment functionality.
Nick S is offline   Reply With Quote
Old 07-10-2016, 09:04 AM   #6
motorhead
Why not just latch the seat bealt and then get in? I never tried that with the camaro, but have with others.
Just a thought.
Old 07-10-2016, 09:24 AM   #7
summit1le
Drives: 15 Lexus RCF, 17 Vette Grand Sport
although I can't verify the speed and rate of the air bag deployment while running aftermarket seats and 6 points. I hit head on while slightly offset towards the drivers side, and the drivers air bag and curtains deployed . I am not sure why the passenger air bag did not deploy, I can guess that has more to do with the seat weight sensor not being installed, therefore the system thought there was no occupant.
2013 Summit 1SS 1LE w/NPP, SW 1 7/8" Long Tube Headers, CAI Intake, Ported TB, Cammotion 224/232 113 LSA, BTR Valvetrain, Melling Oil Pump, 468 HP 423, Apex Catch Can, Tank Plates, RPM 4 Point Roll Bar with SCCA/NASA Cross Brace, Schroth 6 Point Han's Harness, OMP WRC Front Seats, F.M.T Trailing Arms, F.M.T Solid Aluminum Subframe Bushings, Moreno Motorsports Camber Plates, BMR Bushings Front and Rear, Essex/AP Racing Radi-Cal Endurance Front Brakes, Quantum Brake Cooling Ducts, ZL1 Rockers, ZL1 Air Deflectors, Heritage Grill, Pfadt Springs.
summit1le is offline   Reply With Quote
Old 07-10-2016, 11:36 AM   #8
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
My understanding is that the front bags are 2 stage, basically 2 gas generators in each bag. The SDM determines the severity and direction of the impact & decides the timing, which bag to activate & for the fronts, how many generators to fire.
I tried buckling the OEM belts, even went behind the seat. The male portion digs into my side & it is in the way of harness. It might be different if just the buckle and not the webbing. I'll search salvage yards and try that first. Failing that I'll add a switch.
summit1le, correct(my understanding), the pass bag won't deploy if the occupancy sensor is not triggered. I.E.: Activate the light above the mirror.
Old 07-10-2016, 10:44 PM   #9
Og Neon
Lover of Speed
Drives: 2018 ZLE
For like $5 bucks on Ebay or Amazon you can guy a seatbelt dummy plug. It is what I am using in my z/28 and and what I have used in previous cars where I have installed a harness for the track. Much easier then trying to rewire things.
Og Neon is offline   Reply With Quote
Old 07-11-2016, 01:10 PM   #10
MRBZ28
MRBZ28's Avatar
Drives: 2014 Z28
If you go to your chevy dealership parts department and tell them you need a seatbelt extender and give them your vin number they will order you one, thats what i did.
when I got it i cut the end off. I plug it in when Im using my 6 point harness. there was no cost from the dealership for the extender.
MRBZ28 is offline   Reply With Quote
Old 07-12-2016, 09:01 AM   #11
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
I like free! I'll try this first, thx for the tip
EDIT: called the dealer, got two on order.........free / perfect!
