08-20-2016, 05:01 PM | #1 |
Drives: 1968 firebird Join Date: Jul 2016
Ls3 Rocker arm question.
Hey guys, I have been building my 416 ls3 from a bare block. It's almost time to start looking into rocker arms. Anybody using the scorpions? Engine specs are a 416, with a stage 4 BTR cam. AFR 230 heads. Any suggestions or opinions would be great. Thanks
08-20-2016, 06:57 PM | #2 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I'm not running Scorpions but I am using T&D Rockers, mine is a 418 solid roller but the quality is excellent so I'm sure there non adjustable LS rockers are of the same quality. May be worth looking into.
08-20-2016, 09:11 PM | #3 |
Stock or stock with bronze bushings.
Nick
Corvette Z06 -1200ish rwhp |
08-22-2016, 07:52 PM | #4 |
Drives: 2014 Chevy SS Join Date: Nov 2014
Scorpions are aluminum. No thanks.
I'd do the Comp Cams Ultra Pro-magnums or OEM rockers with the Straub bushing upgrade. KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 Last edited by KW Baraka; 08-22-2016 at 08:13 PM. |
08-22-2016, 08:04 PM | #5 |
old school chevy rodder
Stock is actually my tuners choice. I have to agree with unreal..LOL
08-22-2016, 08:29 PM | #6 |
Why are the scorpions so expensive? The comp mags are almost identical in price.
08-22-2016, 10:14 PM | #7 |
08-22-2016, 11:18 PM | #8 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
Just replaced comp cams trunnions with Smith Brothers bushings. If my headers ever show up I might drive the car before the new year.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
08-23-2016, 02:44 AM | #9 |
Drives: 13' 1LE Join Date: Apr 2012
stock rockers with stock bearing. Almost zero thread of them failing, and this is from my abusive reading on LS1tech for the last 10 years. Its not like they wont fail. A lot more lifters are failing from what I read.
CHE bushing upgrade seems like a nice and safe option.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
08-23-2016, 07:50 AM | #10 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Stock seems to work well for many. I've been running Comp Ultra Gold rockers for 4 or 5 years now with no issues at all. A good choice if you want roller tip.
08-23-2016, 07:52 AM | #11 |
I do want roller tip. I'm going to take a look on them.
08-23-2016, 11:45 PM | #12 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
Stock arms with Straub Technologies bushings is a bullet proof set up.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
08-24-2016, 07:00 AM | #13 | |
What Unreal and others said.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
