Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 09-08-2016, 03:10 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
Arrow GM HIGH PERFORMANCE Z/28 UPGRADE KIT - BEST PRICE & FREE SHIPPING W/JUICED!
The Z/28 is the first high-volume production road car to employ racing-derived DSSV® (Dynamic Suspensions Spool Valve) damper technology from Multimatic.™ The dampers rely upon a pair of self-piloted spool valves to control fluid through tuned port shapes rather than conventional deflected disc dampers. The design of the inverted-monotube front strut and aluminum-body monotube rear hydraulic dampers offers maximum response, stiffness, and tuning optimized for the track, with the highest level of damper predictability, accuracy, and repeatability. The unique dampers are the center of a comprehensive suspension package that also includes higher-rate coil springs, smaller-diameter solid stabilizer bars, and higher-rate suspension bushings. The dampers are matched with optimized stiff spring rates and stabilizer bars in both the front and rear to reduce body movement in hard cornering and acceleration. Also included in the package are front ride-and-handling links, rear upper control arms, rear trailing links, and toe links which have upgraded stiffer bushings designed to reduce cornering compliance and increase durability on the track.
Z/28 SUSPENSION PACKAGE
1LE SUSPENSION PACKAGE
Juiced1 is offline   Reply With Quote
Old 09-20-2016, 08:59 AM   #2
Juiced1
Turn your SS into a 1LE with one click......Or grab the Z/28 package and give us a call for some LS7 power level upgrades.
Old 10-03-2016, 09:01 AM   #3
Juiced1
GM track proven set ups.
Old 10-16-2016, 10:44 AM   #4
Juiced1
Great suspension kits that are track proven.
Old 10-20-2016, 06:56 PM   #5
Gee
Silver Ice
Gee's Avatar
Drives: 2011 1LT Coupe SIM
Will these work with 2011 v6 lt?
Gee is offline   Reply With Quote
Old 11-03-2016, 09:09 AM   #6
Juiced1
I do not believe these will fit a V6 but you can turn an SS into a track proven monster.
Old 11-19-2016, 10:06 AM   #7
Juiced1
Sick track set up from the General!
Old 12-12-2016, 07:43 AM   #8
Juiced1
Track proven set ups
Old 12-27-2016, 08:25 AM   #9
Juiced1
Handle like a Z28....we can get the rims you need too.
Old 01-08-2017, 05:14 PM   #10
Juiced1
Proven set ups
Old 01-23-2017, 09:08 AM   #11
Juiced1
Great proven track kits
Old 02-13-2017, 08:19 AM   #12
Juiced1
Old 02-26-2017, 07:22 PM   #13
Juiced1
Z28 handling package
Old 03-15-2017, 08:58 AM   #14
Juiced1
Go from a base SS to a track terror
1le, suspension kit, z28
