Old 10-10-2009, 01:45 PM   #1
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
DIY - de-chroming and painting tail light trim rings
I decided to begin the process of ridding myself of all the chrome on the car...step one was the tail lights trim rings.
I needed a couple of bits of material....
600 and 800 grit sandpaper
Dupli-color CP 199 Adhesion Promoter
Dupli-color DA 1605 Flat Black
I pulled the trim rings (pain in the rear, but did not have to remove bumper...http://camaro5.com/forums/showthread...ght=tail+light ...also...the rear looks AWFUL with the trim rings out...you can clearly see the 'slots' where they belong).
Used 600 grit paper to sand the trim rings...was satisfied when they began to look like brushed aluminum.
Cleaned thoroughly, let dry. Masked off tabs.
Applied 2 light coats of adhesion promoter...10 minutes between coats and 30 minutes before color.
Applied 2 lights coats of flat black, followed by a medium coat (10 minutes between coats)
Let dry and there were some bad spots...I had the spray can too far away and the paint was 'drying' before it even hit the trim ring.
So....waited for 24 hours and wet sanded the rough spots out with 800 grit.
Satisfied, I applied two more coats of flat black. I then followed with clear coat...which gave a glossy appearance I didn't like. I then went over the clear coat with a final coat of flat black.
I'm satisfied with the results...
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 10-10-2009, 01:53 PM   #2
2032Ceta
Drives: 2010 Camaro/2009 Nissan Rogue
Damn...that looks awesome. I cannot stand the chrome crap on my car...
2032Ceta is offline   Reply With Quote
Old 10-10-2009, 01:54 PM   #3
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
Nice job bro. I'm curious whether flat black or gloss black would look better on CGM.
(there is a DIY section lol, probably gonna get moved)
Chewy is offline   Reply With Quote
Old 10-10-2009, 01:55 PM   #4
Blood
Blood's Avatar
Drives: 2003 Silverado z71 1500
Damnnn dude really? that looks awesome. Is there anyway I can take it to someone to get done, because I dont know how to do that stuff well lol.
Blood is offline   Reply With Quote
Old 10-10-2009, 02:04 PM   #5
themossman
themossman's Avatar
I have a feeling the emblems will get pulled and painted to get rid of the little bits of chrome as well....
Missed you this AM!! You going out to the cruise-in this evening???
The flat black would probably look better IMO...they look 'natural' like other black parts on the car (fog/DR lights trim, lower rear valence, etc) If the car was black...glossy black would probably look good, otherwise I think it would be a distraction.
As far as DIY section....I thought this one more appropriate under cosmetic mods...that's where I went searching for help....
Current Summary:
Old 10-10-2009, 02:18 PM   #6
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
looks nice.. will be a winter project for me.
franknbeans is offline   Reply With Quote
Old 10-10-2009, 02:51 PM   #7
Batman0837
Drives: '10 CGM 2SS/RS # 71394
Very nice! Will be looking to do something similar when I get my CGM...
Batman0837 is offline   Reply With Quote
Old 10-10-2009, 02:59 PM   #8
rickerda
rickerda's Avatar
Drives: 2010 Camaro 2LT RS
I've seen several post where people removed the taillight trim and I liked it. But I like that much better.
rickerda is offline   Reply With Quote
Old 10-10-2009, 03:32 PM   #9
Infern0
Bring It
Infern0's Avatar
Drives: In Between
So money and you don't even know it.
Infern0 is offline   Reply With Quote
Old 10-10-2009, 03:38 PM   #10
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
That looks awesome! Way better than using weather stripping...good job!
How do the bezels pop out?
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 10-10-2009, 03:41 PM   #11
teamlowes48
NFIRNO
Drives: 2010 Inferno Orange Camaro
would you mind sharing the product brands with us. I you know what works why test another brand? Thanks
teamlowes48 is offline   Reply With Quote
Old 10-10-2009, 03:43 PM   #12
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
great job looks good, i'll be adding this to the list to do when my car gets here
Old 10-10-2009, 03:45 PM   #13
dmo
dmo's Avatar
Drives: 2SS RS
Send a message via AIM to dmo
That is a sharp piece of DIY modification. I painted the front emblem a flat black but noticed when I removed the crappy plastic chrome it started to deteriorate on the underside and return to a regular plastic. I have an option coming down the pipe line later in the year to replace them with custom billet logos.
Back on topic... the tail chrome pieces on my black camaro would look pretty slick how you did it or with a glossy finish.
I've also been wondering what my car would look like with the body paint a matte black
dmo is offline   Reply With Quote
Old 10-10-2009, 03:54 PM   #14
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
You know what- I thought I was gonna hate it, but it actually looks really good... Nice job, looks very clean. If this catches on, these would be pretty easy aftermarket parts to produce in plastic... Probably start seeing them in a variety of colors, to match the car maybe?
