09-27-2016, 07:47 PM | #1 |
Drives: 2012 Orange 2SS/RS Convertible Join Date: May 2016
Modding my vert
So I have had my vert since Memorial weekend, and I drove it for a while , and I do love my car. But as a lot of us feel, it seems 400 HP should be slamming us back harder in the seat. So I started a while back, and found a LS3 catback with an GMPP axle-back, and put that on. Definitely helped in the sound department. Not too loud for cruising in a vert , but sounds pretty good. I do hear the AFM more with it though. Next I found a Cold Air Inductions intake and a Range device. Put the intake on and definitely helped a little with pickup and more throttle noise. And the range device completely got rid of the AFM. Next I found a Apex Race scoop and washer relocation kit. Installed those and a small amount more pickup and a little more air intake noise and seemed a little more exhaust at full throttle. Today I went ahead and ordered the SCtX4 from DynoSteve. I'm hoping this will give me a nice little bump in the ole seat of the pants feeling. Only thing else I am contemplating soon is some high flow cats. I do love this car , but boy can it be expensive!!!
09-27-2016, 09:30 PM | #2 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
Good looking ride.
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
09-27-2016, 11:12 PM | #3 |
09-27-2016, 11:50 PM | #4 |
Drives: 2013 Camaro 2SS RS Convt. Join Date: Mar 2011
SSweet ride! Love the color!
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
09-27-2016, 11:53 PM | #5 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
I know what you mean. It's called the MOD BUG...... NICE CAR enjoy. The tune will really wake the car up.
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
09-28-2016, 07:17 AM | #6 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
You can see in my sig what I have done to mine. Mods are expensive and yes you will lose your warranty, I already sailed on that boat.
But, it comes down to what you really want out of your car and how long you intend to keep it. I went with my mods because this is the car I always wanted. I will be looking to do a cam next year and that will probably be all I am going to do. You can only use so much power for the street. You have a great looking car, now search your soul for what you really want it to be.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
09-28-2016, 08:18 AM | #7 |
Drives: 2013 ZL1 M6 Convertible Join Date: Apr 2013
Nice Ride! I know it won't be cheap but if you want a really big boost.
Super Charge it!
Mild to Wild Switch, Roto Fab CAI, Big Gulp, Washer Relocation, Ported Throttle Body, Rough Idle Road Race Cam, Supporting Valve Train Upgrade, Dynatech Long Tube Headers Ceramic Coated and High Flow Converters, Injector Dynamics 1025 cc, 22.5%Overdrive Balancer Pulley, Fuel Pump Voltage Booster, Moroso Catch Can.
Jannetty Installed and Tuned. 675 RWHP 630 RWTQ 11.325 1/4 Mile Time @ 124.53 MPH |
09-28-2016, 09:43 AM | #8 |
Thank you! Yours looks good too. Different color scheme. Wow, you have seriously modded yours. I bet your seat of the pants feeling isn't lacking.
09-28-2016, 09:45 AM | #9 |
09-28-2016, 09:46 AM | #10 | |
09-28-2016, 09:48 AM | #11 |
09-28-2016, 10:58 PM | #12 |
I went the bolt on route with my 02 z28, this time i decided to do it differently and went straight to the twins, but yes modding cars can be costly but if you do it your self and enjoy doing the installs its well worth it, and then when you run out of money to do mods there is always forza.
Cai intake and a few other mods😎
09-29-2016, 09:42 PM | #13 | |
09-30-2016, 12:02 AM | #14 |
I went with hp tuner, im trying to learn how to tune and i must say there is a lot to learn lol, and as far as forza 3 i have been playing it for a couple days and been enjoying it
