10-26-2016, 11:33 AM | #1 |
Drives: 2015 Z28 Join Date: Sep 2016
2015' Z28 Supercharged ?
I'm getting the itch to supercharge my 2015 Z28 with an LSA or LS9 blower. What would be needed to convert it besides the LS3 to LS7 intake adapters. Will I have to buy all new accessories. Thoughts and ideas are all welcomed.
10-26-2016, 11:39 AM | #2 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
What about this kit. https://whipplesuperchargers.com/ind...product_id=176
10-26-2016, 11:44 AM | #3 |
Redline did a eforce on one, I think the whipple and heartbeat are nicer, but.
http://www.superchevy.com/how-to/eng...m-and-headers/ |
10-26-2016, 02:34 PM | #4 |
Drives: Twin turbo G8 GXP Join Date: Dec 2012
A twin turbo Z28 would be bad ass..
10-26-2016, 02:54 PM | #5 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
after supercharging my camaro I really noticed the added weight on the front end. I know the Z/28 are built for handling so I don't know if I would supercharge it. I think, and correct me if I'm wrong, the maggy system adds a total of almost 80 lbs to the engine compartment. If I were to start over I would go turbo just because those systems are lighter and have a better balanced set up for the track.
10-26-2016, 03:08 PM | #6 | |
Drives: 2010 Aqua Blue Camaro 2SS/RS Join Date: May 2013
Now my ECS kit that I have is around 75lbs I believe. Either way the turbo kit I had was heavier than both my super charger and your super But that could be just the kit I had others may be lighter
10-26-2016, 03:31 PM | #7 | |
Too much is never enough!
AGP has already done a TT Z28 you should look into that.
This dont weigh 100 pounds, and you won't have the heat soak like you will with a PD blower.
10-26-2016, 03:36 PM | #8 |
Drives: 14 1le turbo Join Date: Oct 2015
Just do heads cam intake.
2014 1LE 2SS/RS
Huron Speed turbo kit |
10-26-2016, 03:57 PM | #9 |
Drives: T Join Date: Mar 2015
x2 on the head cam intake LS7 build.
10-27-2016, 08:37 PM | #10 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
10-31-2016, 04:16 AM | #11 |
THE U
Drives: Camaro 1SS/RS Join Date: Jul 2015
H/C/I or AGP TT if you desire boost.
10-31-2016, 07:41 AM | #12 |
Drives: 2013 ZL1 Join Date: Jan 2015
For some reason this bad boy was running 12.20's @ 122. It was a clean install and made 630whp on the dyno.
2013 A6 ZL1
10-31-2016, 01:11 PM | #13 |
Drives: All things Turbocharged Join Date: Dec 2010
The LS7 takes hardly any boost to make good power. You really have to balance everything right on a Z28 build.
10-31-2016, 01:39 PM | #14 |
'It's an experiment'
NA all the way. You'll need to deal with heat if you SC. It's a constant battle to keep IAT Temps in check. Cam it and update the heads. This is assuming you want to track your car.
While I'm not a Z28, I do have the LSA kit and I road race it... -Don
747 RWHP 794 RWTQ
