Old 11-04-2016, 08:52 PM   #1
Bo White
Bo White's Avatar
th400 driveshaft
Well since I can't get a 1 piece to work to my liking in my car I just took the stock 2 piece and had the front cut and welded for the th400 slip yoke. Smooth as a baby's ass now all the way up to 75mph cruise. I know there's a 1 piece made just for this application that seems to work but I'm picky as hell. So far I'm liking it a lot. We will see how durable it is.....
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-04-2016, 09:14 PM   #2
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
My one piece feels almost stock. Vibrates just a tad
camarosspower is offline   Reply With Quote
Old 11-05-2016, 12:14 AM   #3
Bo White
Bo White's Avatar
Yeah that's the consensus of peeps I've talked to. I'm picky as hell
Totalled:
Old 11-05-2016, 11:15 AM   #4
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
My one piece has no vibration at all but I was very careful when shimming the transmission mount to get the right angle off of the tail shaft to match parallel to the pinion angle on the differential. I also hung a plumb bob off the centre of the crank at the balancer and marked the floor then did the same off the centre of the pinion gear on the diff. I snapped a chalk line between the two points and the hung the plum bob off the tail shaft of the transmission and lined it up on the floor mark before tightening the rear of the transmission down.
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 11-07-2016, 09:29 AM   #5
pancherj
Drives: 2010 Camaro SS
This! I did the same thing. I couldn't believe how far off my crank centerline to diff centerline was when I did my 4L80E swap. I checked it with the stock TR6060 also and it wasn't even close. It was off by about 3/4" at the end of the tailshaft housing.
pancherj is offline   Reply With Quote
