Old 12-23-2016, 07:29 PM   #1
ADM PERFORMANCE
Drives: Anything I want
HOW IT'S MADE at ADM PERFORMANCE
ADM Performance builds 2010 Camaro SS for Army Veteran.
I promised I would build his car to not only perform well but also have the reliability built in that he deserves.
The recipe:
ADM Performance Forged 378 cid LS3
ADM Stage 2 CNC Ported Heads
ADM Stage 2 Cam
Ls7 Lifters
Wiseco Pistons 4.075
Callies Rods
Ls3 Crank
LSA Valvecovers
LSA Supercharger
ADM 6 Rib 2.38" Pulley
Stock 6 rib Balancer
Stock Accessories
New Battery
New LS7 Clutch
New LS7 Flywheel
New Slave Cylinder
Trans fluid upgrade - Royal Purple Syncromax
Diff fluid Upgrade
Brake Fluid Upgrade
Tr7IX Spark Plugs
ZL1 Fuel Pump
ADM Programmed FPCM
Fast 85 lb Injectors
Kennebell boostapump
Stainless Power Headers 1 7/8
Magnaflow 16483 Competition Exhaust
GMPP 1LE Suspension upgrade with shocks,springs,swaysbars and links
ADM PERFORMANCE is offline   Reply With Quote
Old 12-23-2016, 07:35 PM   #2
ADM PERFORMANCE
Day 1 - Disassembly
So the first thing we do is disassemble
Old 12-24-2016, 05:54 AM   #3
ADM PERFORMANCE
Now the cleaning process
Every time we pull one apart we clean them so that when they leave they are better than when they arrive - BEFORE
Old 12-24-2016, 07:16 AM   #4
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
You guys go beyond the call of duty on your work. No other shop puts in this much work with builds. Glad to see this car is going to a deserving person and it will be done right. I love when people ask me who built my car and I get to say it was built by the best, ADM Performance.
MODS:
Old 12-24-2016, 07:18 AM   #5
ADM PERFORMANCE
Thanks
Thanks for the kind words and Merry Christmas
Old 12-24-2016, 01:25 PM   #6
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Nice work as usual. Where do you guys get the fender protectors?
RealQuick is offline   Reply With Quote
Old 12-24-2016, 02:01 PM   #7
hammdo
'It's an experiment'
hammdo's Avatar
http://lsa-conversion-store.myshopif...ace-protection
I have this product. Keep it in the box and wrapped so no dust sticks too it. Works great!
-Don
747 RWHP 794 RWTQ
Old 12-24-2016, 02:51 PM   #8
RealQuick
-Don
Thanks!
Old 12-24-2016, 07:27 PM   #9
ADM PERFORMANCE
End of day 1
So it takes 8 hrs to get to this point -
Old 12-24-2016, 10:37 PM   #10
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Andy, are you using the stock crank?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 12-25-2016, 02:24 PM   #11
ADM PERFORMANCE
Yes it will use a stock crank👍
Old 12-25-2016, 09:26 PM   #12
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 12-26-2016, 06:40 AM   #13
ADM PERFORMANCE
We got the shortblock - Assembly time
We have all of our shortblocks built here locally KB RACING ENGINES to our tolerances,they have been building them for me for 15+ years and offer a fantastic product at the end of the day.
Pics - Oil pump choice
We wanted to show the difference between what comes standard in an LS3 Camaro Engine and a ZL1 Lsa engine. Since we are putting a supercharger on this engine we have decided to go with the LSA PUMP for more reasons than 1.
Old 12-26-2016, 06:45 AM   #14
ADM PERFORMANCE
Engine assembly 2
As we go together
