Old 12-26-2016, 01:18 PM   #1
BTRSS
BTRSS's Avatar
Drives: 2011 Camaro SS Supercharged
Which Shifter?
Ok, so I want to replace my factory Hurst shifter with either a MGW, Hurst or Barton and am curious to what everyone thinks is the best. I have a friend with a Barton but don't know anyone with a Hurst or MGW. Opinions?
BTRSS is offline   Reply With Quote
Old 12-26-2016, 01:19 PM   #2
BTRSS
BTRSS's Avatar
Forgot to add, my Camaro is a SS with a Whipple Supercharger, COM CAM, methanol injection for 785 HP at the flywheel. Thanks.
Old 12-26-2016, 06:13 PM   #3
macSS
macSS's Avatar
Drives: 2012 SS Camaro LS3
MGW all the way...Built like a tank and have not missed a shift....you will love it
2012 Ashen Grey LS3_ARH 1 7/8 Long tubes_Pypes Exhaust Axle Back_C.A.I._
Bo White Ported Throttle Body_Custom Black Anodized Fuel Rails_3:91 Rear
ARP Stainless Bolts_MSD Wires_Elite Engineering Catch Can_MGW Flat Stick_Stewart Warner Pro Gauges_BMR Rear Suspension_ZL1 Rear Swaybar
427 HP To The Wheels_Tuned and Dyno'd by ECS
macSS is offline   Reply With Quote
Old 12-26-2016, 07:52 PM   #4
mmaattppllaayy
Drives: '10 Camaro 2SS
Another vote for MGW. I had a hurst for 2 years and switched to mgw. Should have just went with mgw to start with. Hurst rattles and is rougher. Mgw also feels much tighter with no slop.
mmaattppllaayy is offline   Reply With Quote
Old 12-27-2016, 01:51 PM   #5
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
HURST---5 1/2 years and No Problemo
splashlog48 is offline   Reply With Quote
Old 12-27-2016, 04:39 PM   #6
huggett
Drives: 2015 Camaro 2SS LS3
I have no experience with the Barton or Hurst, but I do LOVE my MGW!
huggett is offline   Reply With Quote
Old 12-27-2016, 04:52 PM   #7
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Had the factory short-throw Hurst. Researched. Went with MGW. Installation was straight forward. Tighter shift gates. Like it. Also, was able to attach the old school T-handle Hurst shift "knob." Recommended.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 12-27-2016, 09:13 PM   #8
BTRSS
BTRSS's Avatar
Well boys, I like what I'm hearing and it looks like the MGW is the shifter of choice. The install video and the test ride they show really seals the deal. Thanks for all that replied.
Old 12-31-2016, 08:54 PM   #9
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
I got the MGW and had Don install it,looked like a pain without a lift
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 01-01-2017, 11:35 AM   #10
BTRSS
BTRSS's Avatar
I talked to Don about it, he didn't really want to install it in mine due to all the custom painted console. He was afraid it might get scratched. I'll probably touch base with him in a month to see if he's still weary about it. I did talk to the boys at NE Tire in Attleboro (they installed a lot of stuff for me) and they new exactly how to install the MGW, so we'll see.
How do you like the MGW? I've nothing but good things about it.
Old 01-01-2017, 03:04 PM   #11
Stingr69
'69 Owned Since '79
Stingr69's Avatar
MGW is a nice piece. Installed that and their Race Knob to replace the OEM regular stock shifter and it was an improvement. That said, I later pulled the MGW out to install a pre-owned GM Hurst. The GM Hurst is quieter than MGW and still works great.
In my case, the MGW solved a problem I just did not have. Sold the MGW for close to what I had in it. The MGW Race Knob is absolutely necessary in my opinion and it fits perfectly on the factory GM Hurst shifter. Best setup for me. Your results may vary.
Old 01-03-2017, 10:02 AM   #12
djcfuzz
Do somethin fun every day
djcfuzz's Avatar
Drives: 2012 45th V6 RS M6
djcfuzz is offline   Reply With Quote
Old 01-03-2017, 10:21 AM   #13
CGbambam
Drives: 2011 Camaro 2SS
MGW man, you won't regret it
CGbambam is offline   Reply With Quote
Old 01-03-2017, 01:10 PM   #14
perfucto
perfucto's Avatar
Drives: 2013 ZL1
MGW
perfucto is offline   Reply With Quote
