02-02-2017, 10:36 AM | #1 |
Drives: LSX FTW Join Date: Feb 2016
Audio Gurus Help!
Alright, so when it comes to audio I know the basics.
However, I purchased the x3 T harness and ordered a Kicker CX series amp to power my 12" Memphis Sub. So here's my problem, I'm getting engine/alternator whine noise coming from the speakers. I know it's engine noise because it's only happening when car is running and gets progressively louder when rpms go up. I'm using 8Guage positive and negative wire straight to the battery, I've tried moving the ground but the noise still doesn't go away. I've tried lowering the gain ect on the amp as well but still no fix. Very frustrating. Would the PAC SNI-1 fix this or what the hell is going on?
#Gapped
02-02-2017, 01:31 PM | #2 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
Engine noise is a PITA, there are many causes but here are some basic rules which will correct 99% of all ground problems and generally speaking, buying a noise loop/filter is a last resort.
02-02-2017, 02:29 PM | #3 |
Thanks Snowman, I suspect it has to do with the RCA cables... since it goes away if they are disconnected. they are the crossover type of RCA's not the cheap straight ones but not sure of branding. I have moved the ground around with no luck. the RCA's were looped and getting hot, they are pretty long. I will try to find shorter ones. the heat on them went away when I switched the hi-lo input on the amp. on the x3 t harness does it matter what rca's you use? left rear or front? and what should it be set on the amp? low or high input? I have decided to try to a ground loop, if it isn't fixed I will try another amp?
#Gapped
02-02-2017, 02:44 PM | #4 |
Drives: 2015 Camaro LT Join Date: Sep 2016
Unless you have unshielded RCA cables, I would be surprised if that is where the issue lies. Alternator noise typically is on the power source. That is where you want the filter... on the power source to the amp. I'm not familiar with PAC's products, but something like the NF10 is probably what you're looking for.
EDIT: As for the amp, the gain should be all the way up. Your hi/lo switch will determine how much sub gets into the mix, and you will have to do that by ear. The fact that your rca cables got hot when messing with that switch is crazy. I would make sure those are properly shielded audio cables. Also I see that the amp has both input and output rca connectors. Make sure you are plugging yours into the correct jacks... the inputs. Beyond that, I would use the rear speaker outputs on your harness. Most head units send more bass to the rear speakers. Last edited by Jazzzed; 02-02-2017 at 04:03 PM. |
02-02-2017, 05:40 PM | #5 | |
#Gapped
