02-21-2017, 05:35 PM | #1 |
Readiness Codes
Just replaced the battery in the 2010SS, wondering how many miles to drive it until the codes are set? 30 day vehicle transfer time period is up and my NYS temp. 10 day inspection is up LOL... looking to get it inspected soon though
02-21-2017, 05:44 PM | #2 |
Drives: 2010 Camaro 2SS Join Date: Feb 2017
10 days from my own personal experiences. (10' 2SS) Had a buddy take less time. (12'1LE)
Sent from my iPhone using Tapatalk Pro
"To be prepared for war is one of the most effective means of preserving peace." -- George Washington ___________________ #CANYONSS |
02-21-2017, 06:19 PM | #3 |
Happen to know if he driven it and how many miles? I had another similar situation with my previous 05 Monte SS had the battery unhooked was doing stereo and speakers, couple days later went to get it inspected failed of course
02-21-2017, 08:18 PM | #4 |
I texted him, he said he put down 80 miles / highway.
02-21-2017, 08:23 PM | #5 |
'It's an experiment'
Evap takes a while. I had to use my tech2 and even that took 1.5 hours from cold start to shutdown tests:
http://www.camaro5.com/forums/showpo...&postcount=627 It takes several cold start cycles at least 8 hours apart for just that test to complete... -Don
747 RWHP 794 RWTQ
02-22-2017, 01:09 AM | #6 |
Drives: 2015 Camaro LT Join Date: Sep 2016
The Evap requires at least 3 minutes of driving 55mph, and you have to also idle on a cold start with the rear defogger and the air conditioner running for at least 3 minutes.
02-22-2017, 06:38 AM | #7 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
There is a driving procedure to reset the readiness codes. This takes about 20 minutes to do. Evap will take much longer but you only need 3 of 4 codes to pass in order to pass inspection in NY. I went through this with my Avalanche a couple of years ago when I replaced the battery and tried to get it inspected the next day. Not sure what the procedure for the Camaro is, but I found the one for the Avalanche by google.
02-22-2017, 01:05 PM | #8 |
Drives: 2011 1LT Join Date: Mar 2012
As Zed Sled mentioned, you can complete the drive cycle, in order to test/ rest/ clear the codes.
General Motors Driving Cycle A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes. To perform an OBDII Driving cycle do the following:
. For the longer periods of holding a steady speed, I recommend setting the cruise control. Of course, you may find it difficult to find a place where you can hold a steady speed for five, or even three minutes, as around here, it's very difficult to go five minutes on ANY road without finding some jackwad who simply MUST drive at 20 MPH under the speed limit. At the same time, of course, you'll have somebody riding your tail, demanding that you go 20 OVER the limit. Your coast- down--- without touching the brake or clutch down to 20 MPH--- is best down on on upgrade. Do it on the level, or on a downgrade, and it'll take so long to reach 20 MPH that the people behind you will lose their freakin' minds, and pass you on the shoulder, or into oncoming traffic, or whatever. For me, I can only complete the full drive cycle late at night, with less traffic around. Maybe Peru has better opportunities on the road for completing the drive cycle, but while it is possible here in CA, it CAN be a pain in the butt. On the other hand, TYPICALLY 200 miles of just "regular" driving will USUALLY clear the codes... but not always. A while back, before I learned of "drive cycles," I had a car that the mechanic kept sending me back out to drive: I drove 600 miles before the damn codes cleared. |
02-22-2017, 01:19 PM | #9 |
Drives: Miss Con Ception Join Date: Aug 2016
The OP is in Peru, NY. IIRC that's upstate NY. Not South America.
Get on the highway for about 30-40 minutes going 60 - 80 MPH and everything will heat up and you will be good to pass. These cars cry for you to blow some fuel through them.
2011 1SS/RS LS3 CGM
02-26-2017, 05:00 PM | #10 |
Well so far i have been taking it out for some drives and now down to, two not readies EVAP and Catalyst are what's left, i just get weary about the troopers being able to scan my plate number... no inspection ticket is not something what i want to get lol
02-26-2017, 07:00 PM | #11 | |
My Dream Car
Drives: 2011 SIM LS3 1SS Join Date: Jul 2009
I had this problem when I had my v6 Camaro. Did all the drive cycles numerous times. still could not get the evap code to go ready. I just simply stopped worrying about it, drove the car and checked it 1x every other week, 600 miles later and 6 weeks later , all monitors went ready. Simply put just drive the car, you will end up doing all the procedures via your normal drive cycles instead of trying to force yourself to follow the procedures and it probably not getting it done.
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
02-28-2017, 05:37 PM | #12 | |
02-28-2017, 06:43 PM | #13 |
As I posted above, get on the highway and go 60-70 for ~40 minutes.
Worked for me. None of my driving around town did.
2011 1SS/RS LS3 CGM
02-28-2017, 06:53 PM | #14 | |
More than 2 weeks as you have to do a combo of city and highway driving. This is what I had to do to get it ready. Dealer can do this, but I had a tech2: http://www.camaro5.com/forums/showpo...&postcount=627 Here is the drive cycle from the manual: http://www.camaro5.com/forums/showpo...&postcount=616 -Don
747 RWHP 794 RWTQ
