Old 02-24-2017, 08:48 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Angry FML if it's not one thing it's another
Well the past couple days I've noticed my oil pressure at idle has dropped alot. The engine has 1,800 miles on it.
Normally it would sit around 1.8 bar (26.46psi) with Brad Penn 10w 40 oil. I've changed the oil 5 times and cut open all filters. The first had normal break-in material second had a tinny amount then the last 3 have been Completely clean.
Currently my oil pressure is sitting at 1.2 bar (17.64psi) when warm. My car on the original motor has never been below 1.6 bar.
Now every oil change I use a Delco oil filter. Except the current oil change I'm on right now.
Someone had placed the wrong filter in the Delco box so I used one of the shops (off the shelf) oil filters. The brand is "mighty". That shop I use to work at for 10 years and we always ran that filter with no problems but the cars are just normal daily drivers not performance.
I'm hoping it's something with the oil filter holding back pressure.
The engine doesn't over heat nor does it make any pecking or knocking sounds.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 02-24-2017, 08:52 AM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
General rule is 10psi for every 1k rpm. Always being higher when cold.
More to come.
Black_SS10 is offline   Reply With Quote
Old 02-24-2017, 10:28 AM   #3
2010_camaro
It's never been this low.
Old 02-24-2017, 11:20 AM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
My nearly stock LS3 sits at 22psi warm idle sometimes 19psi. If I do an Autocross event or hit the strip I've seen it idle at 17psi. I usually blip the throttle just a little and it will go back to 22psi and slowly fall to about 18psi. Not saying it's normal but I'm curious as well.
Old 02-24-2017, 11:36 AM   #5
2010_camaro
If I drive mine normal I'll see the 1.2bar oil pressure. Cold idle is 3.8-4bar
Old 02-24-2017, 11:50 AM   #6
1989GTA
Drives: 1989 GTA Trans Am
What is the oil pressure at say 1500rpm or cruising down the highway?
1989GTA is offline   Reply With Quote
Old 02-24-2017, 01:27 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I recall years ago with the 4th gen stuff someone noticed they had different/lower oil pressure with a different brand filter.
Certainly easy to swap it.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 02-24-2017, 02:29 PM   #8
Casey Jones
2015 Black 2SS/RS L99
Drives: 2015 2SS automatic
If it isn't the filter, them checking the sensor and wiring is in order.
Not an uncommon issue in my 02 Z06 Corvette.
Casey Jones is offline   Reply With Quote
Old 02-24-2017, 03:59 PM   #9
2010_camaro
2.6bar ish at 2k rpm
Old 02-24-2017, 04:43 PM   #10
CamaroDreams76
Thats about what mine is. What filter do u run
Old 02-24-2017, 08:15 PM   #11
2010_camaro
Well I have brass in my filter. No silver but the engine toast I guess.
Old 02-24-2017, 08:54 PM   #12
1989GTA
That does appear to be a lot of brass.
Old 02-24-2017, 09:46 PM   #13
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Didn't you just rebuild that motor??
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 02-25-2017, 06:04 AM   #14
2010_camaro
Yep
