Old 04-04-2017, 10:38 PM   #1
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Looking for DIY Seat cover removal
Going to be looking into new seat covers for my factory seats since mine are pretty worn out. Anyone got a how-to on how to swap these? Power leather seats for what it's worth.
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 04-05-2017, 07:28 AM   #2
ron123
ron123's Avatar
Drives: 2014 2SS/RS
My driver's seat developed a tear after using the heated seat, set on high on a 16 degree day; it was replaced under warrantee.
Did not do the swap of the cover myself, but did stay at a Holiday Inn Express ... lol.
Actually, watched the process of cover replacement by the Chevy Dealer and snapped some photos. It is fairly straightforward but tedious work.
First step is to move the seat forward in the track and remove the two bolts located in the back of the track. (careful to not break the welded on nuts loose - saw that warning in another thread). Then, when the bolts are out, the front of the track can be disengaged from the retainer. Unplug the seat wire harness. Remove headrest and then have a buddy help carefully take the seat out and place on a table. Having it sitting up high will make working on it much easier because access is needed to all parts of the seat frame.
There are plastic channels around the perimeter of the cover that pop out to release the cover. The seat switch control panel/side plastic cover has some fasteners under it (shown hanging off the table on the right side in the picture above). And then there are about 20 hog ring fasteners that go through the rectangular slots in the foam cushion and attach the cover to the wire seat frame (cushion rectangular slots shows up well in the photo). The rings are a pain to release because they are located way under the cover. Those rings are the key to the fit and finish on the Leather seat. The rings keep the seat cover firmly locked in to the frame and stop it from sliding under the high g-forces of the Camaro ;-)
The bottom seat cover attaches in the same fashion as the top.
The big white flat material covering parts of the foam in the picture are the seat heaters - the grids shows through in the photo and look like a race track ... I will never use the seat heater on high setting again. On the 16 degree day this winter the seat did get extremely hot on the high setting; that weakened the leather, next day saw the tear.
If you go with aftermarket covers maybe a good idea to see what method they use for cover attachment before deciding on a particular brand. The OEM covers are form fit and have tension on them which gives mostly a smooth wrinkle free finish.
Did notice that the OEM "Leather" cover is about 50% leather and the rest is upholstry material on the edges and sections not in clear view.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 04-05-2017, 11:51 AM   #3
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
i'm going to be purchasing the oem inferno covers. Trying to score them cheaper than what I found them at, but if not I may buy piece by piece until I get all of them and pick a warmer day in the summer to do this
Old 04-05-2017, 12:27 PM   #4
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Good strategy, if patient there are some good bargains out there. A while back I saw a set of Inferno covers and also headrests real cheap. After my seat cover was replaced under warrantee, I've found a few parts at great prices that I bought up for spares down the road.
Always liked this Indy design on the Inferno
Old 04-05-2017, 01:12 PM   #5
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Yeah, i'm just not sure if the inferno headrest covers come with the SS stitching
Old 04-05-2017, 08:59 PM   #6
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Been looking at Inferno for a couple of years ...
Yes - OEM Inferno available with SS Logo.
On ebay now for $99 for the pair (new):
Old 04-06-2017, 09:56 AM   #7
kraut1971
BITCHN Camaro
kraut1971's Avatar
Drives: SOLD! Back in the looking zone...
Not sure how it'd come out on the IO, but I posted the following thread with a free customer embroidery file head restraint covers:
http://www.camaro5.com/forums/showthread.php?t=462775
BITCHN
kraut1971 is offline   Reply With Quote
Old 04-06-2017, 11:41 AM   #8
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
http://www.ebay.com/itm/2010-14-Cama...RSZu-W&vxp=mtr
Looks like a special part number. Good looks on that, gonna add that part number to my other post in the cosmetic section so that anyone else looking can check these
