Old 10-27-2009, 01:40 PM   #1
Tran
Administrator
Tran's Avatar
Arrow Tjin Edition RoadShow Chevy Camaro SS to debut at SEMA show (sneak preview)
As featured on homepage.
Enjoy the sneak peek!
LA HABRA, California, Oct. 26, 2009 - The Tjin Edition RoadShow Chevy Camaro SS in conjunction with General Motors and Real AutoWorks will be debuting in the Air Lift booth (#23633) at the SEMA show on November 3rd, 2009.
With SEMA quickly approaching, the Tjin Edition RoadShow team, led by Neil Tjin, received their brand new 2010 Chevrolet Camaro SS with less than 20 miles on the odometer. Having planned out the design well before the arrival, Neil and the team at Real AutoWorks in La Habra, CA got right to work and within a days had the LS3 motor pulled, the interior completely gutted and the rest of the car taken disassembled.
On the exterior, the Tjin Edition RoadShow Camaro SS features super slick, yet subtle modifications. The factory black paint has been replaced with a custom DuPont Cromax Pro two-tone green paint scheme; on the outside, the Camaro’s body has been sprayed in a custom metallic green, while the engine bay and body accents were sprayed in a darker matte green finish. To accentuate the exterior of the car, Revolution Styling supplied a front lip spoiler and vented hood, LightWurkz remodeled the Camaro’s headlights, taillights and fog lights with LED technology, and Ignited HID provided the lighting for the headlights and fog lights.
When the time came for the Tjin Edition RoadShow Camaro SS to be outfitted with its rollers, Neil and iForged worked together and created a one-off set of 22” and 24” iForged Seneka wheels finished with carbon fiber barrels, brushed faces and black bolts. The custom three-piece iForged wheels are matched up with an equally impressive set of Falken FK-452 tires measuring 255/30/22 up front and 275/25/24 in the rear to keep the Camaro on track when on the road. To keep the SS under control, SSBC designed a custom big brake kit especially for the build which included bright purple eight-piston calipers along with crossed-drilled and slotted rotors.
Although all of the above upgrades are key, the fully digital air system suspension provided by Air Lift helps to bring it all together. The digital set up will allow the Tjin Edition RoadShow Camaro SS to be lowered or raised with the simple push of a button all while maintaining it’s stellar handling capabilities. Finishing off the suspension and handling upgrades on the SS, PFADT Race Engineering stepped up and provided front and rear sport bars which.
Real AutoWorks really showed off their creative skills with the transformation of the Camaro interior and in-car entertainment system. Real AutoWorks was responsible for rewrapping the entire Camaro interior in a custom t-tech and suede material, which features purple double stitching throughout to match the purple SSBC calipers. The stock Camaro seats and gauges were replaced in favor of carbon fiber Status Racing / Tjin Edition RoadShow racing seats and a plethora of GlowShift digital gauges. The Camaro’s in-car entertainment is highlighted by two 12” Realm Audio flat subwoofers, two amplifiers, two components sets, and a Azentek smart mirror which features a touch screen LCD monitor, built in Bluetooth, integrated GPS Navigation, and rear view camera. Real AutoWorks customized the trunk section with custom speaker boxes, an amp rack, NX carbon fiber bottle holder, and an enclosure for the Odyssey batteries and Air Lift tanks and compressors.
Finishing off the Tjin Edition RoadShow Camaro is an engine bay that will have people talking, thanks to the guys at Vortech and JE Pistons. Turnkey Engine Supply rebuilt the stock LS3 motor. The block was disassembled, deburred, honed to a 4.070" finished bore size then finally cleaned for assembly. Turnkey then measured each component to verify the clearance was correct for a forced induction application. The engine was then assembled with a K1 Technologies 4.000" stroke forged crankshaft, K1 Technologies 6.125" H-beam billet rods,
JE Pistons forged "FSR" Pistons, 8.8:1 compression ratio, JE Pro Seal Rings: 1.2mm steel nitrided top rings, 1.5mm Napier second rings, 3.0mm low tension oil rings, ACL Main and Rod Bearings, ARP Head Studs and Turnkey Engine Supply Pushrods. Once the 415 cubic inch motor was reinstalled, all the fluids were topped off and Royal Purple XPR 5W-30 motor oil was poured into the motor. Next it was time to bolt on the Vortech supercharger, American Racing headers, MagnaFlow exhaust, BDL Automotive fuel rails, and Nitrous Express direct port set-up. Vortech not only provided the supercharger kit, but they were also responsible for the installation, tuning and calibration of the car. A S.P.E.C. twin-disk clutch was installed to go with the new power that can be found under the hood of this Camaro. Aesthetically the engine bay has been outfitted with BDL Automotive clamps, GM Addiction billet caps, and a Unique Auto Design carbon fiber fuse box cover and engine shroud.
Make sure to check out the Tjin Edition RoadShow Camaro at the SEMA Show from November 3rd to 6th in the main hall in the Air Lift booth (#23633) and if you can’t make it to SEMA this year, don’t worry as the Tjin Edition RoadShow Camaro will be on display around the country in 2010 as part of the Tjin Edition RoadShow.
Old 10-27-2009, 01:46 PM   #2
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
looking sharp!
Old 10-27-2009, 01:47 PM   #3
The Dark Knight
Batmobile in Disguise
The Dark Knight's Avatar
Drives: 2009 Pontiac G8
ni0ce!
The Dark Knight is offline   Reply With Quote
Old 10-27-2009, 02:04 PM   #4
rjdapilmoto
DAP-ONE [COTW - 12/23/13]
rjdapilmoto's Avatar
Drives: 2010 - 2SS/RS IOM
Sweet!!
rjdapilmoto is offline   Reply With Quote
Old 10-27-2009, 02:05 PM   #5
jcamere94z28
jcamere94z28's Avatar
Drives: None
usually not a fan of green in sport cars.. but wow.. that's gonna look sweet.
jcamere94z28 is offline   Reply With Quote
Old 10-27-2009, 02:11 PM   #6
C4
ERNEST
C4's Avatar
Drives: 2012CAMARO 1LT RS CONVERTIBLE
damnnnnnnnnnn
looks good
C4 is offline   Reply With Quote
Old 10-27-2009, 02:29 PM   #7
Foc-Dog
Pickedup Charlene on 9/18
Foc-Dog's Avatar
Drives: '00 Ford Focus, '10 2LT/RS BLK
Are those halo tail lights? Nice!!!!
Foc-Dog is offline   Reply With Quote
Old 10-27-2009, 02:35 PM   #8
Tech
Tech
Tech's Avatar
Drives: 2010 Camaro 2SS
nice...i cant' wait till SEma!!!!
Tech is offline   Reply With Quote
Old 10-27-2009, 02:37 PM   #9
Bowtie Guy Z28
Bowtie Guy Z28's Avatar
Drives: 98' Z28 08 CC Z71 2010 SS/RS
I'm diggin that color...
04/10/09 1100 04/14/09 2000 04/21/09 3000
05/21/09 3400 05/30/09 3800 VIN....14159 Colorado Members check out CCOTR.ORG
The "Z": BBK Intake, 85 MM Power TB, Smooth Bellow, SLP Lid, K&N, SLP Panhard, Strut Tower Brace, Spec Stage 2+ Racing Clutch, MSD Wires, Performance Exhaust
Bowtie Guy Z28 is offline   Reply With Quote
Old 10-27-2009, 02:42 PM   #10
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
That thing is gonna look sweet
Old 10-27-2009, 02:49 PM   #11
montej23
montej23's Avatar
Drives: 2011 VR Camaro
looks really good and well thought out plans to make this camaro look even better
montej23 is offline   Reply With Quote
Old 10-27-2009, 02:57 PM   #12
PNYSLAR
Summit White 2012 ZL1 M6
PNYSLAR's Avatar
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9
outstanding!!!!!!!!
PNYSLAR is offline   Reply With Quote
Old 10-27-2009, 03:05 PM   #13
JBz007
Broke College Student
JBz007's Avatar
Drives: 2000 Hyundai Elantra
This is looking nice, I don't like the rendered color but the actual paint looks pretty good. can't wait to see the whole thing!
God created man to create the Camaro
JBz007 is offline   Reply With Quote
Old 10-27-2009, 03:20 PM   #14
Ferrarimk13
Ferrarimk13's Avatar
Drives: Hopefully a Camaro in a year
i think the color is terrible but all the other stuff is awesome. Like the CF, and the brakes.
Ferrarimk13 is offline   Reply With Quote
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
