Old 05-05-2017, 05:33 PM   #1
Allanski
Drives: Car
2011 Camaro Convertible 1000 Hp for sale
2011 Camaro Convertible 1000 HP for sale
at the THE TORONTO SPRING CLASSIC CAR AUCTION - Sunday May 7/17
https://www.collectorcarproductions....%20&EventID=96Name:  1000 hp dyno chart.jpg
2011 Camaro SS RS Convertible spec sheet
ENGINE
- Performance Built Engine 427 CID Bored to 434 at 9.1 to 1 Compression
- GM LSX iron block new version #19260089
- Callies Dragonslayer 4.00” stroke Crankshaft
- JE Forged Pistons
- Carillo H Beam Connecting Rods
- Clevite Coated Main and Rod Bearings
- ARP Main Studs
- Cometic LSX head gaskets
- ARP Head Stud Kit
- Comp Cams Billet Camshaft
- Comp Cams short travel Lifters
- JPP Billet double row timing chain
- Melling High-Volume 50 psi Oil Pump
- Comp Cams Pushrods
- GM LSX DR cylinder heads #19166979
- PAC Titanium Retainers
- PAC Custom Springs
- PAC Titanium Bead Locks
- T&D 1.9:1 Roller Rockers
- GM LS7 aluminum intake manifold
- Edelbrock elbow
- GM 90mm throttle body
- Alcohol Injection meth kit
POWER ADDERS
- F2 Procharger
- Precision 46mm wastegate
- Procharger monster blowoff valve
- Custom fabricated stainless headers
- Turbonetics front mount intercooler customized for more air flow
- ID 2000 Fuel injectors
- Squash return HP Fuel System
TRANSMISSION
- Jake’s transmission 4L80 Stage 5 with transbrake
- Jake’s 3600 stall converter
- B&M magnum ratchet shifter
- Dynatech one piece aluminum driveshaft and safety loop
- G force 9" fabricated IRS rear end with 3.73 gears
Remember your US dollar is now worth about $1.40 Canadian!!!
Allanski is offline   Reply With Quote
