![]() Drives: 2011 2SS/RS Callaway Join Date: Feb 2014
My TSP LQ9 408 Stoker Build
Hey there, i posted up a couple months back talking about how my camshaft chewed up a piece of my roller lifter and then to pixie dust to the bottom of my oil pan. It took a minute for my shop to diagnose that problem. They pulled my engine and discovered what happened. I had a couple of options that i could've went with but I thought this was my second best option. It wasn't the cheapest but my car was at 700whp and figured I was on that fine line with a stock lower end. I didn't have intentions of forging my motor this season but life has an amazing way of reminding you how it goes sometimes. Unfortunately this happened at the busiest time of the year for a tuner, spring.
My first option was just to replace the broken parts but found out the whole motor had to be gone through because of all the fine pieces of metal. He would've sent my block and heads to another shop to be checked for issues that weren't seen. Since the motor, regardless was in pieces, if I was going to forge it, now's the time. For my shop to go through and forge the internals, not including the crank was expensive. On top of taking a really long time. In michigan there's a small window of driving time with events and shows and that window was closing on me. I searched for forged motors and came across Texas Speed and Performance. They had one in stock that is a 408 stroker with a cast iron block that was fully forged including the crank. This was a cheaper option for me with more potential I thought, so it was a no brainer. I guess the only downsides of this would be not a matching motor and depending on how you look at it, a cast iron block that weighs about 100 pounds more then a aluminum block. But there's pros and cons to that. I thought about both of those and decided, it doesn't matter to me. I have so much money in my car and its so modified that I don't see myself selling it. So once i decided that, I ordered the block. I was lucky that they had one in stock or that would've just pushed things farther back. If I had more money, I would've went with their 416 stroked aluminum block but that was almost $2000 more, but they didnt have that in stock regardless. Since my heads needed to be gone through, checked and cleaned. I decided just to upgrade and save some time and get a better product with some Trick Flow Heads. I also upgraded to Innovators west 10% dampener and I'm going from a 6 rib to 8 rib to get all I can out of this blower. So those were my options or I guess I could've sold it, Lol, yeah right. Its getting close and I figure that in less then 2 weeks, I will have my car back. Its been in the shop for two months, waiting on decisions and parts but now all those are answered. This thing is going to be bad to the bone! Its essentially a new motor plus its bigger, can never go wrong with that. I also went with TSP cam and cant wait to hear how it sounds.
2011 Callaway SC572 2SS/RS, TVS 2300 Supercharger, 1-7/8" Kooks LT Headers, Fast 85# injectors, E85 Flex Fuel Conversion, Fore Twin Fuel Pumps, MGW flat stick short throw shifter, McLeod RXT twin disc clutch, Liberty Gears Tremec trans, DSS 1000 hp axles, Nitto NT555r drag radials, 10#'s of boost, 702 rwhp/ 697 torque, Recaro seat upgrade
This is their engine room and in here he has the block, heads, cam plus some other pieces together. Pushrods coming soon along with the damper.
Here's the damage this bad boy made.
Pictures in order, 1-Motor fresh out of the car after my roller lifter broke, don't mind the car in the background. ![]() 2-Passnegers side with heads removed 3-The roller lifter that broke, definitely not supposed to look like that, lol. 4-This is the front passenger side, right above the 10 o'clock mark a small dash, thats where my lifter and heads kissed
![]() ![]() Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
that looks awesome! I like the iron block. gonna be so much stronger for your blower!
can't wait to see some video! |
Sux on the failure, but the replacement on the way...
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; MGW short shifter; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! 2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock |
#6 | |
I'll definitely show a video
#7 |
Totally sucks. But that replacement though, lol
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Black L99 2SS/RS Join Date: Mar 2014
With the failure set up, what kind of lifters / springs were you running?
How aggressive was the cam? |
#9 |
They were stock lifters and springs. It was a mild comp cam. I don't recall the numbers, I have them somewhere.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Beautiful new motor!
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
So, the old "my dad is a TV repairman" line?
2011 1SS/RS LS3 CGM
#12 |
#13 |
#14 |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
