06-12-2017, 09:12 PM | #1 |
USB Ports not working
Has anyone had any issues with the two USB ports in the center armrest not working? Cannot get a thumb drive or my IPhone working with CarPlay when I plug in.
06-12-2017, 09:30 PM | #2 |
I love crepes
Check the cable you're using when connecting the iPhone. I had some issues and it turned out the cable wasn't sufficient.
06-12-2017, 10:02 PM | #3 |
Drives: 2017 2SS Stick Hyper Blue Join Date: Jan 2017
06-13-2017, 01:51 AM | #4 |
Drives: 2023 2SS1LE Join Date: Feb 2017
i am having the same issue as well however just on one of the 2 usb ports.
06-13-2017, 09:50 AM | #5 |
Drives: 2017 2SS A8 Black Join Date: Mar 2017
Every once in a while I get a "media not found" error. I unplug my USB and wait a minute, then plug it back in, maybe I switch which plug. That usually does it.
Man is born free, and everywhere he is in chains
06-13-2017, 11:11 AM | #6 |
SoCal Mayhem
Drives: 2017 2LT Hyper Blue Metallic Camaro Join Date: May 2009
I have that issue sometimes too. It also happens in my Stingray. I've always chalked it up to MyLink issues.
06-13-2017, 01:09 PM | #7 |
Try this type of USB devise: SanDisk
A couple guys here recommended it. I suspect it is the Silver Bullet. I've ordered a couple. |
06-13-2017, 01:11 PM | #8 |
Make America Fast Again
Drives: 2016 HBM 1SS - M6 Join Date: Sep 2016
I have this issue. The dealer installed my spectrum lighting kit incorrectly and my car is full of little wiring bugs. Working on getting it sorted out in July.
06-13-2017, 01:24 PM | #9 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
I use these in 32Gb, never had an issue.
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
06-13-2017, 01:54 PM | #10 |
Thanks for advise. Just disconnect the negative cable for about 15 minutes and it reset itself. USB working again. Easy fix.
06-13-2017, 03:32 PM | #11 |
SoCal Mayhem
It even does it with my iPhone though. CarPlay shows up on the screen and when you touch it, it doesn't open. It's weird.
06-13-2017, 03:36 PM | #12 |
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2) Join Date: Jun 2016
I get this too. In my case, it's usually another Lightning cable going bad. They're extremely sensitive to flexing and twisting, and as I still haven't found a satisfactory mount for my 6s plus, the phone usually slides around on the passenger seat while I drive. The lifespan for a cable in my house is probably about 4 months.
06-13-2017, 04:21 PM | #13 |
SoCal Mayhem
i put my phone in the cup holders sideways...definitely need to find another spot for it for when i have drinks.
