06-17-2017, 01:33 AM | #1 |
Drives: 2013 Camaro SS - Blue Ray Metallic! Join Date: Jan 2013
Here come my Twins!
I'm returning from deployment in a few weeks and then shortly after I'm dropping the camaro off at GPI. My current mods are in my signature and this is what I'm deciding to add:
-Twin 58/62mm Ballb Turbos from AGP Fuel to support 900-1k+ (not positive what setup yet) -Built 4l80e swap - imagine I'll have to be lower than a 4k stall -Forged pistons/rods, leaving everything else stock on the L99 besides what's in my sig. Replacing the SS4VVT with a custom ground turbo cam from GPI And going with a 15" conversion in the rear to run 325/50/15 ET Street Rs That's about all my budget can fit, I'm concerned about the rear end and that's about it. What are your thoughts? I plan to be around the 900whp range, we'll see what it makes. I'm more concerned with running 9s and getting as deep as I can into them! While still having the ability to do rolls. I'm leaving the 3.91 gears that I have now, I think it will actually be a pretty good combo with the built 4l80e. I'll still be able to reach 155mph or so. Let me know what you guys think, like I said my main concern is the rear end, but I won't be launching it that much tbh, until I can afford to build it!
SS4VVT GPI, ported/milled heads, GPI radius rod insert manifold, Circle D 5c 4k triple disc stall, 3.91 gears, kooks 1 7/8+HF cats, Magnaflow X Pipe-Deleted Resonators, Borla ATAK, Vararam DRX, VMAX CNC ported TB, BMR Toe Rods, Trailing Arms, Front/Rear Sway Bar, 1.25" lowering springs, LCA. Tuned by Ryan at GPI.
06-17-2017, 06:49 AM | #2 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Maybe a 2 step or a trans brake to build boost off the line, that will be harder on the rear though. Going to be a fast car
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
06-17-2017, 09:12 AM | #3 |
Drives: Z06 wannabe Join Date: Feb 2015
Yea dude, that is going to be nasty, I would consider the ZL1 diff from the start since you will need a custom driveshaft for the 4l80 swap anyways. Of course get proper Drag suspension so she sits up right off the line!
Good Luck man... keep us up to date!
Apex Focused
06-17-2017, 09:58 AM | #4 |
'It's an experiment'
GPI will do you right! Can't wait to see the results...
The staff there are top notch... GPI is building my forged SC motor, that will be exciting! Most importantly- thank you for your service.... -Don
747 RWHP 794 RWTQ
06-17-2017, 10:31 AM | #5 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
I preach planting the power before producing the power. I don't practice what I preach. So, I will soapbox my hypocrisy and say - do a suspension drag package along with a stronger differential. I do not believe a built-up stock diff will live long. Most economical diff is a ZL1, and the 3.73 will be more than tall enough. I think the 3.91 will show you more tire spin than you'll be happy with, and you'll even get more tire spin in the higher RPMs rowing through second and third gears with the 3.73. Just saying. Back to the suspension - something like stronger trailing arms and toe rods at minimum. And, with the 15" conversion you'll need different lower control arms. Fast is beautiful.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
06-17-2017, 11:44 AM | #6 |
Totally forgot to mention I will also be trying to squeeze a trans brake and two step into the build as well, as it will be essential to get those solid ass launches! Slipped my mind when writing the post though, thanks for the reminder!
06-17-2017, 11:46 AM | #7 |
Yeah that's a good point, I do have some suspension right now, but will have to swap my BMR trailing arms/toe rods to the 15" conversion ones from Carlyle! I'll look into the cost of swapping diffs! Thanks much I will definitely be posting back when the car is done sometime in August hopefully, I'm super excited! Can't wait ha.
06-17-2017, 11:47 AM | #8 | |
And no problem my friend, I enjoy what I do; for the greatest country on earth
06-17-2017, 11:49 AM | #9 | |
06-17-2017, 05:30 PM | #10 |
Drives: 14 1le turbo Join Date: Oct 2015
I'm doing a similar setup and went with a 3.73 zl1 diff. The stock diff should last at 900 and a auto. I've been waiting on sps haymaker heads for almost three months now.
Twin billet s261 4l80 rpm lvl5 Sdpc iron 365 Lil John custom cam Id 1700s, twin 450s, meth blah blah blah
2014 1LE 2SS/RS
Huron Speed turbo kit |
06-17-2017, 05:49 PM | #11 |
Drives: IOM 2SS/RS Join Date: Dec 2011
Sweet build!
I have a similar build TH400 3500 stall Built 6.0 iron block Twin agp 65's Agp twin walbro 450's Allky control meth system I would highly recommend a transbrake and 3.45 gears, turbos love load. Also I would recommend meth, nice way to prevent detonation if you're not going with E85. Good luck! |
06-17-2017, 09:59 PM | #12 | |
06-17-2017, 10:04 PM | #13 | |
I'm not the expert though and I trust GPI, I will just see what they think is the most optimal setup! I'll read more into it though, people seem to keep saying go 3.45 or 3.73!
06-17-2017, 10:49 PM | #14 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
Your gonna love it. Id recommend a fuel system from agp. I just installed a dual pump e85 setup from them and am very happy with it. I would suggest putting that 15" conversion part of the budget towards a zl1 diff. Otherwise it will be a matter of time before a stock unit goes especially with 15" fatties. Go with some 17" for now until you do the 15"s.
EDIT: Just saw youll mainly be doing rolls so you should have better luck with that stock unit but I wouldnt stick too much into it. Ive learned the hard way to do it right the first time.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
