#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 06-28-2017, 09:29 PM   #1
black96lt1
Drives: 1996 z28
Axle shaft bolts came out today!
So I was driving and I feel a slight vibration. No other noises or anything just a slight vibration that I first thought was from the road(contruction zone) or tire. But I wasn't getting any alerts about tire pressure and then after probably less than 3 miles from the start I hear and feel something let go in the rear and then a grinding noise. And then it felt like the transmission was slipping so I immediately pull over and get out I can immediately smell the differential fluid and look under and see the drivers side axle shaft has decided to divorce itself from the diff!
Car is a 2016 2ss auto with 17k miles. I've never abused it either. I drive it fast but never anything that would hurt the rear end like that. Definitely disappointed in it. Still love the car but definitely a downer.
black96lt1 is offline   Reply With Quote
Old 06-28-2017, 09:37 PM   #2
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
That's a bummer. There have been other members here that have had those bolts back out as well.
Eric SS is offline   Reply With Quote
Old 06-28-2017, 10:07 PM   #3
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
There has to be something that can be done to try to prevent this from happening. A good soaking with Loctite 290 maybe?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 06-28-2017, 10:57 PM   #4
black96lt1
Drives: 1996 z28
A mechanic on another board posted a TSB that called for longer bolts
TSB # 16-NA-399
Subject: Information on Replacing Half Shaft Fasteners with Revised Parts
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
ATS-V
2016
2017
LF3, LF4, LT1, LT4
CTS-V
2015
2017
Chevrolet
Camaro
2016
2017
Involved Region or Country
North America and N.A. Export Regions
Condition
The technician may need to perform a repair that requires the half shaft bolts to be removed.
Information
This bulletin advises the Service Technician of new longer bolts and lock washers required to be installed during any repair that requires the half shaft bolts to be removed or replaced.
Three retainer assemblies required per half-shaft.
Each retainer (3) requires 2 bolts (1) and 2 washers (2) to make a retainer assembly.
Where applicable, each axle assembly uses 3 retainer assemblies per side.
Each repair kit contains 6 bolts and 6 washers. 1 kit for each half shaft.
Replacement of all axle bolts are required during repair.
Correction
If half-shaft has been separated from the differential:
Remove and discard only the half shaft bolts.
If required, clean and reuse retainers.
Replace the shorter bolts (1) with a new longer bolt (2) and washer.
Install the lock washers onto the bolts.
Install bolt and washer assembly into retainer.
Torque bolts to proper torque specifications. Refer to Fastener Specifications in SI.
Service stock half shafts may include POA bolt/retainer assemblies. These assemblies may require rework with longer fasteners.
The new half shaft bolts must be removed, measured and discarded if the length is incorrect.
Parts Information
Note: To obtain the bolts and washers, fax the form included in this bulletin to the GM Warranty Parts Center (WPC). Request WPC #816.
Use the Vehicle Identification Number (VIN), SI, and the GM Electronic Parts Catalog to determine the proper part numbers for the half shaft, if replacement is required:
Description
Part Number
Qty
Bolt/Washer
WPC #816
1 kit (6 bolts/6 washers)
IMPORTANT NOTE WHEN PRINTING THIS FORM: If the form prints out on two pages, make certain you fax BOTH pages so that the WPC receives all the needed information. Missing information will delay or prevent the part from being shipped.
Parts Request Form – Warranty Parts Center
Use this form ONLY for U.S. and Canadian Dealers. Export markets and Mexico Dealers must contact their regional Technical Assistance Center for assistance.
To: Warranty Parts Center
e-mail: warrantypartscenterUSA@gm.com
or WPC Fax: 248-371-0192
Attn: Temporary Service Parts
Part Being Requested: WPC #816 Bolt and Washer kit
Old 07-02-2017, 08:39 AM   #5
LibertyHill
Did that post contain the actual document or only the text? I'd email it in and try to get a set for myself since there is no part number for them.
Old 07-02-2017, 10:07 PM   #6
black96lt1
Drives: 1996 z28
He put up only the text but here is a little better look at it:
http://www.cadillacforums.com/forums...formation.html
You might be able to get it from the dealer with the TSB# or wpc #816
Old 07-03-2017, 07:54 AM   #7
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
This would be bad on a road course at high speed. I still can't believe a lot of issues have been going on for over a year now and nothing has been corrected on the assembly line. I do know for those that fix these issues themselves it never gets reported to GM to let them know how big of a problem these really are. I hope this one doesn't happen to me when I'm tracking my ZL1.
KLR ZL1 is offline   Reply With Quote
Old 07-03-2017, 10:26 AM   #8
Stex
Drives: 67 goat, 69 goat ram air III
If you can find a part number for the new longer bolts, you could go to a Chevy parts and run your vin for the bolts and see if the new or old bolts come up???
Stex is offline   Reply With Quote
Old 07-03-2017, 01:23 PM   #9
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
Prior to that did you ever notice any other vibrations at any other time? Reason I am asking is like you I don't punish the car but over the last 3-4 months (have had it 13 months now) I have noticed a transient vibe around the 33-35 mph range and again at 43-45. Doesn't last long but I notice it and it is not consistent. I have been tracking other vibration discussions but have yet to cross anything similar. In addition I am not overly worried about it right now as it is barely noticeable and I know that a dealer road test would probably come back with a negative finding. Negative in this instance being their inability to duplicate it.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 07-04-2017, 08:01 PM   #10
black96lt1
Drives: 1996 z28
never any other issues. It started within 5 miles of it letting go. It did have the differential noise but that was only when the weather was below 45 and only for the first mile or 2.
Old 08-09-2017, 04:42 PM   #11
stook2001
Drives: 99 M3, 04 STi, 16 2SS
Just took my car in for a semi-related issue and figured I would post here rather than adding a new thread.
Noticed last night pulling into my driveway that I had some kind of scraping / grinding / squeaking noise from the rear of the car. Took it in this morning (dealer is fortunately about 1 mile or so from my house). I immediately assumed that my diff was toast since I still have some diff noise like pretty much everyone else. Anyway, turns out that axle bolts were under torqued. From the explanation that I was given, it was the opposite end of the axle to the OP, ie. at the hub. Car has 7k currently. Not abused AT ALL. Not one burn out, never raced, etc. pure daily driver.
It's a mystery to me how this could cause the symptoms that I had but they retorqued the bolts to spec and it does seem to fixed for the moment. From the service guy's description, they seemed rather mystified by it as well but apparently the GM service protocol calls for checking this and sure enough it seemed to fix it.
I expressed my concern about wear to the axle or hub splines given the noise but was assured it was completely fine (not so sure about that, but probably not much I can do about it).
stook2001 is offline   Reply With Quote
Old 08-10-2017, 01:16 AM   #12
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Well... thats not supposed to happen.
soloknight6 is offline   Reply With Quote
Old 08-10-2017, 11:03 AM   #13
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Drives: 2017 Chevrolet Camaro SS 1LE
Regardless of any issues, axle bolts on a car like this are something that I would recommend checking at each oil change...if the bolts are backing out, you can most likely catch it then. I checked mine at 1000 miles, and they are all good.
SS 1LE is offline   Reply With Quote
Old 08-10-2017, 11:04 AM   #14
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Maybe you have one of the bad torque converters?
