08-25-2017, 02:38 PM | #1 |
Drives: 2012 camaro ss ashen gray Join Date: May 2012
Car went faster 1/4 mile with slower trap speed than previous?
So last time I went to the track it was 100 degrees and my car went 1.8 60ft 120mph at 11.5 consistently...i went yesterday to the track again and it was 80 degrees... my car went 1.7 60ft 117 mph at 11.3.. Why is it trapping slower speeds now but faster time? The only changes made to the car from the first time was went from drag radials to slicks, removed the front sway bar and put drag coilovers in the front...
08-25-2017, 04:34 PM | #2 |
Banned
Drives: Camaro Join Date: Mar 2013
Trap speed don't win races.
08-25-2017, 05:00 PM | #3 |
Traction will do that most of the time.
08-25-2017, 10:46 PM | #4 |
Drives: Ibm SS/RS Join Date: Sep 2013
Usually when you hook up you lose MPH but gain et. When you launch and are spinning, your tires are turning the mph, but you are not traveling in as fast as a forward motion as hooking up. Does that make any sense?
08-25-2017, 10:49 PM | #5 |
Damn you blew me away with that one, I never thought of that. Yea I was hooking better than last time I went
08-26-2017, 09:36 AM | #6 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
lol...wat Bo said...just a longer explanation...once I stop spinnin 60 ft out of the hole my 60 and et(and now cooler air temps comin!!!) will drop too...next trip droppin psi to 15-16..if that doesn't work I guess gonna have to look for slicks too...(and I haven't even cracked open the motor(if you call springs/pr/bushings that ROFL)...good luck man...gonna watch your progress...keep postin...
