Old 10-26-2017, 09:33 PM   #1
GreenAppleLS3
Drives: Synergy Green SS Camaro 6 speed
Turbo oil drain
Has anyone ran there oil return down into the oil drain plug
Synergy Green Camaro SS LS3 TH400, Stock Ported heads, Night Fury cam 4600 Circle D stall. 3.91 gears and rotofab intake, obx headers,
GreenAppleLS3 is offline   Reply With Quote
Old 10-26-2017, 09:41 PM   #2
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Terrible idea. Run it to a valve cover or front cover.
Unavowed is offline   Reply With Quote
Old 10-26-2017, 10:25 PM   #3
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Sounds messy when it is time to change oil.
Mine runs to the front drivers side of the oil pan.
Old 10-26-2017, 10:30 PM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Has to drain above the oil level in the pan
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-27-2017, 12:10 AM   #5
sweet99ss
Drives: 2012 ZL1 Camaro
THIS^^^ the line is going to fill with the oil from your oil pan via gravity lol. To keep from taping the pan I have seen guys use a scavenge pump and run the oil to the valve cover....
~01 zO6~ (Procharged/bolt-ons) SOLD
~05 Vette~ (Procharged/Bolt-ons) SOLD
~98 Z28~ (TMS 408/RPM LVL 6/Circle D4k) SOLD.
~00 SS~ (Forged LS/IIHS 7875 Turbo/RPM Lvl 6/Strange S60) 10.3-141
~2010 SS~ (SLP TVS2300 Blower/Speed Eng LT's)
~2012 ZL1~ (IIHS Twin Turbo)
sweet99ss is offline   Reply With Quote
Old 10-27-2017, 06:02 AM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
Tap the pan?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 10-27-2017, 06:25 AM   #7
fif_gen_powa
Yes drill and tap for a fitting to connect the drain line to ...
8.3@164
Old 10-27-2017, 06:39 AM   #8
GreenAppleLS3
Even with a drain tank that the turbo would feed into that’s above the oil pan with a hose then going to the oil pan.?
Old 10-27-2017, 07:59 AM   #9
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I am actually about to do this tonight for a ysi supercharger. Had to borrow a right angle drill from work. Im thinking about doing it right in front of where the oil cooler used to be drivers side up as high as i can. Ill try and take some pics. Just google Ls turbo drain or drill and tap ls oil pan. All kinds of info pops up
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 10-27-2017, 12:27 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I had a Ysi before turbos and I reused the drain from the Ysi.
Old 10-27-2017, 02:50 PM   #11
bayarea408
bayarea408's Avatar
Drives: T
Have fun, use grease to catch flakes. I bought a "gold plug" magnetic drain plug in the event there was any potential shavings, if you do not drop the pan. When i did the first oil change although a small micro amount of very fine metal i am glad i used it.
bayarea408 is offline   Reply With Quote
Old 10-27-2017, 03:16 PM   #12
bct10985
Aluminum isnt magnetic
Old 10-27-2017, 05:31 PM   #13
GreenAppleLS3
^ hahahahah
Old 10-27-2017, 07:41 PM   #14
bayarea408
bayarea408's Avatar
Drives: T
DOH
still good to have in a boosted motor, not everything is aluminum. But disregard it for the pan tapping scenario, my bad. It was my logic at the time, decisions get hazy late nights in the garage lol.
