Old 11-04-2017, 11:07 PM   #1
sneakypete
OOH..Sneaky, Sneaky!!
sneakypete's Avatar
Drives: 2014 Camaro 2SS/RS 1LE
Exhaust or Tune?
I have Texas Speed long tube headers, catless mid pipes that are running through the NPP mufflers. I recently had a generic P0300 code. I replaced all the spark plugs and the O2 sensors. My car’s exhaust fumes are so damn strong that if you stand behind it while it’s running your eyes will burn and your clothes will smell of gas in a matter of seconds. Is this normal for a catless car or does it sound like my car is running too rich?
I don’t have a wideband to check my AFR but will pick one up if it appears to be running rich.
sneakypete is offline   Reply With Quote
Old 11-05-2017, 05:45 AM   #2
craigd853
Drives: 2010 SS Camaro
It's from not running cats. These help absorb that smell. I running hi flow cats on my 2010 with TSP long tubes and as soon as I switched them out i could smell more fumes. Tuner said it was normal and i do have the AFR gauge installed on my car. He was correct, all good. Hope this helps
craigd853 is offline   Reply With Quote
Old 11-05-2017, 06:15 AM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
That’s called “Merica! Hells yea!” That’s panty droppin powerfume! Lol, jk man, but yea thats normal. If this were my daily, I’d consider putting in a set of universal 3” high flow cats. Might cost you 1hp, and will help with the stink.
The random misfire code could be from a wire touching a header primary, a bad coil or plug. I got some misfire codes when i installed tsp 2” headers, but they went away when i installed a nice thick set of Taylor sparkplug wires and made sure none were touching a header.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 11-05-2017, 09:21 AM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
You did tune the car with a tune ? Its in the tune if the car is running too rich but yes as others said the cats help cut the gas smell and I believe even help make more decel/fuel cut off popping from their heat and make the car legal most places.......And the tune cannot change the smell if your already tuned well with Stoich and you should have the front o2s operational yet with the code for delayed response blocked and the rears disabled.... in the tune..... and well if you got a remote tune things like a preloaded tune can have unless your just not into say a different fan on off or no 1-4 shift or Hill start assist etc.... it adjusts the AFR with preloaded tables hopefully changing things out to maximize on your mods selected for the "Canned tune".
You must be in CAL where you don't have to smog.....or come from somewhere else licensing it, or are waiting the four years or so ? before they ding you get a new car checked..?
Old 11-05-2017, 09:37 AM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
you should touch base with dynoSteve at RDP...you really should get a tune, leavin so much on the table without it...my setup is 50 state legal, no cels, 20+ HWY mileage AND I DD the car unless it's raining or snowin....good luck!
Old 11-05-2017, 09:38 AM   #6
Leo72793
Drives: 2011 2SS/RS
Catless makes it run lean/rich depending on throttle.
Tune can correct it. or high flow cats. it helps reduce the scent alot.
Leo72793 is offline   Reply With Quote
Old 11-05-2017, 02:24 PM   #7
sneakypete
sneakypete's Avatar
Steve did the tune on my car when I changed out the Cam. Ive had catless cars in the past but I don’t remember them being this strong smelling. It may just be the difference in cams.
Old 11-06-2017, 12:13 AM   #8
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
I'm cammed, longtubes, no cats and mine isn't as bad as that.. I suppose getting it checked wouldn't hurt
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 11-06-2017, 07:55 AM   #9
Avenging Orange
Avenging Orange's Avatar
It's hard to help when you leave out important info....like having a cam.....whether it was tuned (canned or dyno). Those things are kinda important....from someone who says they have had modified cars in the past.
That being said. You will always get some fuel smell, even with hi-flo's. But pungent overwhelming is in the tune. The car should really be properly tuned on a dyno if you have a cam.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
