#Camaro6
Old 11-30-2017, 10:01 AM   #1
Six.Two SC
Drives: 2018 Summit White Camaro 1SS
Is the stock ride height the same on the 1SS and 1LE?
1SS coupe that is...
Six.Two SC is offline   Reply With Quote
Old 11-30-2017, 10:14 AM   #2
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
http://www.camaro6.com/forums/showpo...56&postcount=7
See my calculations from that post. Note that both the spring height and overall tire diameter is a bit different.
Based on my calculations, the SS 1LE springs alone are lower than the base SS springs by the following:
Front: 0.336" lower
Rear: 0.579" lower
Overall ride height on SS 1LE (considering both wheel/tire combo and springs) is lower than base SS by the following:
Front: 0.828" lower
Rear: 0.766" lower
Therefor on base SS, the GM lowering kit combined with SS 1LE wheel tire package would sit:
Front: 0.44" lower than SS 1LE
Front: 1.27" lower than base SS
Rear: 0.20" lower than SS 1LE
Rear: 0.96" lower than base SS
Numbers that went into calcs above:
SS 1LE:
Front wheel diameter: 26.73"
Front ground to top of arch: 27.875"
Rear wheel diameter: 27.20
Rear ground to top of arch: 28.0625"
Base SS:
Front wheel diameter: 27.72"
Front ground to top of arch: 28.70"
Rear wheel diameter: 27.58
Rear ground to top of arch: 28.83"
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
vtirocz is offline   Reply With Quote
Old 11-30-2017, 03:15 PM   #3
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
I didn’t do any measurements, but just from eyeballing differently optioned SS’s, MRC seemed to have higher ride height for some reason. Also, the V6 RS coupe seemed a lot lower than my 2SS w/ MRC.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
Old 11-30-2017, 03:33 PM   #4
WhyUMad1LE
Drives: 17 SS 1LE
The 1LE sits a little bit lower, maybe 10-15 mm.
WhyUMad1LE is offline   Reply With Quote
